davisontech Posted February 4, 2012 Report Share Posted February 4, 2012 Just picked up a new '12 Edge and wanted to upgrade the speakers but cant get the door panel off. I have seen the instructions on here for '11s and earlier but I think the '12 is different. I have all the screws out and all the clips are loose but something is holding it in the middle. Doesnt seem there is any screw at the door handle anymore...so not sure what is holding it on. Anyone have any experience with this? Quote Link to comment Share on other sites More sharing options...
Dingo Posted February 4, 2012 Report Share Posted February 4, 2012 (edited) From the PM post, for anyone else: (No dirty car comments) Pull the switch panel up from the armest side. Pull the upper piece from the top. Now that I looked, there is only one bolt at each of the locations and 2 screws at the bottom. When you get all 4 undone, just lift the panel. Edited February 4, 2012 by Dingo 1 Quote Link to comment Share on other sites More sharing options...
davisontech Posted February 4, 2012 Author Report Share Posted February 4, 2012 Worked perfect. Thanks again. Quote Link to comment Share on other sites More sharing options...
ArcherAve Posted May 1, 2012 Report Share Posted May 1, 2012 (edited) Thanks for the detailed photos, really helped! How do the back door panels come off? Edited May 1, 2012 by ArcherAve Quote Link to comment Share on other sites More sharing options...
davej1958 Posted June 4, 2012 Report Share Posted June 4, 2012 Hello, what did you upgrade too on the speakers and in hindsite what would you recommend without breaking the bank ...??? tx Quote Link to comment Share on other sites More sharing options...
Victor Yang Posted June 18, 2012 Report Share Posted June 18, 2012 I added 4 Infinity Kappy 6802.9CF speakers (seems like a pretty popular choice on this board). Sound quality is much better and it only cost me about $155 through Amazon. The speakers aren't perfect if you're an audiophile, but they are cheap and are much better than the stock speakers. Quote Link to comment Share on other sites More sharing options...
melgriffith Posted August 19, 2012 Report Share Posted August 19, 2012 (edited) Hi Everyone: does anyone know how to install the panel back onto the friction clips (or pins). I just had tints installed on the front windows and noticed that both the driver and passenger side door panel was a little loose. As I investigated I could see that the top corner friction clip did not sit completely into the door hole. I even went to Napa to get a door trim tool to help push the friction clip but ended up scratching up the door paint. Any assistance is greatly appreciated. thanks, Mel Edited August 19, 2012 by melgriffith Quote Link to comment Share on other sites More sharing options...
cjd3 Posted August 19, 2012 Report Share Posted August 19, 2012 Make sure the top of the door panel hangs properly on the window sill lip: If it's not on there properly, the rest of the panel doesn't fit tightly. Quote Link to comment Share on other sites More sharing options...
gkfreeze Posted August 25, 2012 Report Share Posted August 25, 2012 Does anybody know how to replace the tweeters in the A pillars of a 2012 Edge with the sony system? Quote Link to comment Share on other sites More sharing options...
gkfreeze Posted August 25, 2012 Report Share Posted August 25, 2012 also have infinity kappa speakers that are 6.5 size with ring adapters, curious if they will fit? Quote Link to comment Share on other sites More sharing options...
Tarawa Posted September 1, 2012 Report Share Posted September 1, 2012 (edited) I'm trying to get the door panel off, removed all the screws and bolts, however it's just not sliding up, feels like there's something else. Any ideas? Thx. Got it off, thought it was like my old 350 and once the screws ame off, the whole panel slid upwards. Got my new speakers in and realized, I need to order some felt strips, cause the panel vibrates against the metal when its really loud =D Edited September 1, 2012 by Tarawa Quote Link to comment Share on other sites More sharing options...
menasci Posted March 26, 2013 Report Share Posted March 26, 2013 What about the back doors? Anyone? Quote Link to comment Share on other sites More sharing options...
Vandussm Posted March 27, 2013 Report Share Posted March 27, 2013 Replaced the factory speakers on my 2013 edge with a pair of Alpines. Huge improvement even with no amplifier and there running off the stock head unit. Quote Link to comment Share on other sites More sharing options...
whoanelli Posted March 27, 2013 Report Share Posted March 27, 2013 Anything beats the stock speakers (well, almost anything). What I need advice on is what people are using to replace the front pillar speakers with. I seem to "hear" them as much if not more than the doors (at least the highs) and would think a high quality replacement would make a world of difference..? Quote Link to comment Share on other sites More sharing options...
Dingo Posted March 27, 2013 Report Share Posted March 27, 2013 I used Boston ISTS. Quote Link to comment Share on other sites More sharing options...
DoubleD Posted July 5, 2013 Report Share Posted July 5, 2013 (edited) Tried taking off the driver's panel today and was unsuccessful. I removed the two screws at the bottom and the two 10mm bolts behind the window switches and upper panel as per above pics. How hard are you supposed to pull up on the panel to have it let go? I was getting to the point where I thought it was going to break if I went any harder. I also found what looks like a little clip in the aft map pocket area which appears to be holding the panel as well. It's in a real tight spot within the pocket itself. Is this new /unique to the 2013 sport models or not even part of the panel fastening? Any suggestions would be appreciated. Edited July 5, 2013 by DoubleD Quote Link to comment Share on other sites More sharing options...
DoubleD Posted July 9, 2013 Report Share Posted July 9, 2013 I gave it another try and discovered that little thing I called a clip is actually my ambient lighting. Still cannot get this panel off and I've read everything I can find online. Any suggestions? I didn't think Ford had changed anything for 2013 so there's got to be someone out there who has done this. Thanks. Quote Link to comment Share on other sites More sharing options...
idreamer24 Posted January 1, 2014 Report Share Posted January 1, 2014 Were you able to get your door panels off? I have a 2013 Edge and was having trouble as well even after removing the screws and bolts as listed in the write-up. On 7/9/2013 at 3:42 PM, DoubleD said: I gave it another try and discovered that little thing I called a clip is actually my ambient lighting. Still cannot get this panel off and I've read everything I can find online. Any suggestions? I didn't think Ford had changed anything for 2013 so there's got to be someone out there who has done this. Thanks. Quote Link to comment Share on other sites More sharing options...
Angelsdust Posted January 11, 2014 Report Share Posted January 11, 2014 So if I remove the 4 bolts as in the pictures above it should come off that easy ? What about the back doors ? Any pictures for that? I haven't tried my luck on it yet but I rather read up on it before I run into issues! Quote Link to comment Share on other sites More sharing options...
good2Bking Posted December 31, 2014 Report Share Posted December 31, 2014 Snake456 shared this You Tube link in his post in the Accessories & Mods thread http://m.youtube.com...h?v=x_1OeYMfwl4 Here is snake456's post: http://www.fordedgef...el-mods-so-far/ Awesome. Thank you to snake456. Quote Link to comment Share on other sites More sharing options...
Randy Johnson Posted February 12, 2016 Report Share Posted February 12, 2016 Has this video disappeared? I was looking for some instructions. I have ordered new speakers for my 4 doors on my SEL and was looking for guidance before they arrive. Quote Link to comment Share on other sites More sharing options...
candurin Posted February 12, 2016 Report Share Posted February 12, 2016 (edited) Not sure a video is really needed. It took me less than 5 minutes to get the door panel off. The bolt locations are clearly marked. Just make sure to lift up when removing the panel (to clear the door lock). Having said that, this should help: https://m.youtube.com/watch?v=ODFY9TS6GsY Edited February 12, 2016 by candurin 1 Quote Link to comment Share on other sites More sharing options...
