Steering wheel vibration
dckotwicki
Just took delivery on a 2010 Edge Limited. Turned in an'07 Edge SEL. I am noticing vibration in the steering wheel while the vehicle is in gear and stopped. Once the car is moving I do not notice it.
The vehicle only has 50 miles on it, but I never noticed this in my '07 Edge.
Any one experience this???
Sounds like you are getting a typical idle speed rroughness from a new, tight engine. Give it a chance to loosen up. may take a thousand miles or so, and if the vibration is still there ask the dealer service department about it. At any rate, I wouldn't get too concerned with as few miles as you have on it. :reading:
  • 2 years later...
Does your problem look like this?
http://www.fordedgef...l-when-stopped/
I guess I have the exactly the same.
BTW, did you find what was wrong?
