Tobias Posted March 13, 2012 Report Share Posted March 13, 2012 I have a 2008 Edge Limited with 92,000 miles. I just got an cost estimate from my local Ford dealer that it would cost $380.00 for spark plug replacement! Is this the going rate?I live in Racine, WI. What have you paid for this???? (I know that the plenum needs to be removed). Quote Link to comment Share on other sites More sharing options...
us11csalyer Posted March 13, 2012 Report Share Posted March 13, 2012 Sounds right with the labor needed. Quote Link to comment Share on other sites More sharing options...
bbf2530 Posted March 13, 2012 Report Share Posted March 13, 2012 I have a 2008 Edge Limited with 92,000 miles. I just got an cost estimate from my local Ford dealer that it would cost $380.00 for spark plug replacement! Is this the going rate?I live in Racine, WI. What have you paid for this???? (I know that the plenum needs to be removed). Hi Tobias. :D To put your mind at ease, I would recommend calling several of your other area Ford/Lincoln Dealers for price quotes. That will give you the best idea as to what the going rate is in your area. Let us know how you make out and good luck. :beerchug: Quote Link to comment Share on other sites More sharing options...
Tobias Posted March 13, 2012 Author Report Share Posted March 13, 2012 Thanks for the replies. Tobias Quote Link to comment Share on other sites More sharing options...
evh Posted March 13, 2012 Report Share Posted March 13, 2012 Note, I plan on replacing the plugs in my 09 this weekend. I ordered the OEM Ford Motorcaft replacements, delivered to my house from RockAuto, for $24.51. Gives you an idea of the labor cost. Quote Link to comment Share on other sites More sharing options...
Platinum White Posted March 13, 2012 Report Share Posted March 13, 2012 Doing a spark plug change is NOT rocket science. I did mine on an 09 SEL last month, took my time and finished in about 2 hours. I have a theory about Service Depts. at dealers. Once you visit, YOU WILL be BACK for something else. I have 71K on my Edge now. The last time it was at a dealer was for a Sirius radio replacement in Jan of 2010 and haven't been back since. My Rule #1 Don't pay someone else to do something you can do yourself. 1 Quote Link to comment Share on other sites More sharing options...
Mazz Posted March 14, 2012 Report Share Posted March 14, 2012 Doing a spark plug change is NOT rocket science. My Rule #1 Don't pay someone else to do something you can do yourself. For those of us who are rocket scientists, however, it's sometimes better to let someone who is a real mechanic work on our cars. Quote Link to comment Share on other sites More sharing options...
akirby Posted March 14, 2012 Report Share Posted March 14, 2012 For those of us who are rocket scientists, however, it's sometimes better to let someone who is a real mechanic work on our cars. http://www.youtube.com/watch?v=lVPsBmhgjTk Quote Link to comment Share on other sites More sharing options...
Pete K Posted March 14, 2012 Report Share Posted March 14, 2012 I have a 2008 Edge Limited with 92,000 miles. I just got an cost estimate from my local Ford dealer that it would cost $380.00 for spark plug replacement! Is this the going rate?I live in Racine, WI. What have you paid for this???? (I know that the plenum needs to be removed). Plenum Gaskets and plugs are $50. It took me 2 hours, and I am certain a dealership can do it in 1 hour. Unless the dealership hourly rate is $160-$320 dollars per hour this us not reflective of the going rate. Quote Link to comment Share on other sites More sharing options...
Tobias Posted April 4, 2012 Author Report Share Posted April 4, 2012 The Ford dealer was $350. I called the Lincoln dealer... $250 + $30(if a new gasket is needed). Also - where is the PCV valve located? Quote Link to comment Share on other sites More sharing options...
Loosecannon1 Posted April 13, 2012 Report Share Posted April 13, 2012 (edited) Most techs in dealerships get paid flat rate , in other words if a job calls for 2 hours and I complete it in 1 I still get paid for the two hours. The PCV valve is located in the valve cover and will require you to remove crank vent tube from the valve which is screwed into the valve cover,once removed you will have no option to replace the pcv as the locking mechanism is damaged during removal. Good luck Edited April 13, 2012 by Loosecannon1 Quote Link to comment Share on other sites More sharing options...
2007Edge Posted September 10, 2012 Report Share Posted September 10, 2012 my mechanic changed mine for 40$ :>) Quote Link to comment Share on other sites More sharing options...
Feirstein Posted September 12, 2012 Report Share Posted September 12, 2012 The only issue with the plug change on the Edge is with early 07's. They sport an extra wire going to a heated PVC valve. If you don't know about this extra wire you will think you have removed everthing needed and pull on the intake valve to remove it and wind up breaking the wire. (Yes, I speak from experience). Be careful out there. Quote Link to comment Share on other sites More sharing options...
showmanmd Posted November 15, 2016 Report Share Posted November 15, 2016 I had a coil go bad in my 2007 5.3l edge and the mechanic quoted me 815.00 to change plugs and coils..I bought oem coils plugs and gaskets from a company in Tennessee for 200.00 I am a 33yr old woman..I changed all of them completely by myself in under 2hrs..I didn't have to replace any tubes.. Believe me if you have a 8mm socket it's definitely worth doing yourself and saving the money 5 Quote Link to comment Share on other sites More sharing options...
WWWPerfA_ZN0W Posted November 15, 2016 Report Share Posted November 15, 2016 DIY for the win!!! 1 Quote Link to comment Share on other sites More sharing options...
macbwt Posted November 15, 2016 Report Share Posted November 15, 2016 I have two Edge's that I have to change plugs in at the same time. Yeah I can do a lot of other things with 600 Dollars. 1 Quote Link to comment Share on other sites More sharing options...
Redbow Posted November 16, 2016 Report Share Posted November 16, 2016 I'm due a 60K checkup on my 2013 Edge. Have a promotional service reminder with a price fo $299.95 for the service. Is that a good price? I live in Greenville, TX. Burke Quote Link to comment Share on other sites More sharing options...
WWWPerfA_ZN0W Posted November 16, 2016 Report Share Posted November 16, 2016 300 is a pretty standard price with plugs and pcv valve included. I think it is reasonable for a dealer rate. 1 Quote Link to comment Share on other sites More sharing options...
