terry and dena Posted March 3, 2012 Report Share Posted March 3, 2012 We have a 2008 ford edge limited and when we adjust the mirrors to the desired location and turn off the vehicle the mirrors return to the previous location it is quite aggrivating! how do we set the mirrors to stay where we want them? Quote Link to comment Share on other sites More sharing options...
FordGuru Posted March 3, 2012 Report Share Posted March 3, 2012 (edited) We have a 2008 ford edge limited and when we adjust the mirrors to the desired location and turn off the vehicle the mirrors return to the previous location it is quite aggrivating! how do we set the mirrors to stay where we want them? check out page 150 of your owners manual to see if you are programming the memory mirrors correctly. Memory seat and mirrors (if equipped) This system allows automatic positioning of the driver seat and outside rearview mirrors, to two programmable positions. The memory seat control is located on the driver door. • To program position one, move the driver seat and exterior mirrors to the desired positions using the associated controls. Press the SET control. The SET control light will briefly illuminate. While the light is illuminated, press control 1. • To program position two, repeat the previous procedure using control 2. A position can only be recalled when the transmission gearshift is in Park (automatic transmission). A memory seat position may be programmed at any time. The memory seat positions are also recalled when you press your remote entry transmitter UNLOCK control and the transmitter is programmed to a memory seat position or when you enter a valid customer code 1 or 2 on the keypad. To program the memory seat to remote entry transmitter, refer to Remote entry system in the Locks and Security chapter.. Note: The seat will not travel to its final position if the key is not in the ignition and the easy entry feature is enabled. Edited March 3, 2012 by FordGuru Quote Link to comment Share on other sites More sharing options...
