Smiley Posted August 3, 2007 Report Share Posted August 3, 2007 Can anybody tell me what you get for $ 65 ? I did not order this option cause I did not know what it was and still don't. Anybody have it and is it worth it , its too late for me since my order is in the system. Thanks in advance . Quote Link to comment Share on other sites More sharing options...
BOBM Posted August 3, 2007 Report Share Posted August 3, 2007 (edited) Instead of two pieces of filler plastic around the spare tire which hold up the rear compartment floor, you get two pieces of plastic which are cut out to provide storage space underfloor for small items like toolkit or trailer hitch. It would be pretty handy to keep such items hidden & out of the way, but if you didn't order it, Ford wants $280 for it through the parts department. A HUGE rip-off for something that should be standard equipment. Edited August 5, 2007 by BOBM Quote Link to comment Share on other sites More sharing options...
HokieOnTheEdge Posted August 4, 2007 Report Share Posted August 4, 2007 Here is the Rear Cargo Management System Quote Link to comment Share on other sites More sharing options...
Drdisk Posted August 4, 2007 Report Share Posted August 4, 2007 Ordered it from the factory, great option for keeping valuables out of sight, or for storing jumper cables, etc. The parts man needs to make a living too, but $280 ? Sorry this pricing out of line ! :rolleyes: Quote Link to comment Share on other sites More sharing options...
scalewoodman Posted August 6, 2007 Report Share Posted August 6, 2007 Edge is still on the 'short list' of replacements for our aging but reliable 2001 Jeep Grand Cherokee... as time goes on, I'm realizing that these will be big shoes to fill! The Jeep has several 'hook points' on the storage area-- 2 d-rings on each side, 4 anchor points in the floor, and lots of other good places to hook. When we travel with our dogs, they are very much appreciated to lash cargo safely to the side (leaving the center area open for dogs) in case of an avoidance maneuver, etc. I use 2 nylon webbed anchor straps and the occasional bungee cord to keep things in place. This, while it may seem like a little thing, is a huge convenience! SO, if the 'cargo management' system is as described, the obvious question is this: ARE there hook points in the Edge or MKX? Little things make a huge difference. At this point, I'm going to have a hard time letting go of the Jeep! Quote Link to comment Share on other sites More sharing options...
MHOsborn Posted August 6, 2007 Report Share Posted August 6, 2007 Edge is still on the 'short list' of replacements for our aging but reliable 2001 Jeep Grand Cherokee... as time goes on, I'm realizing that these will be big shoes to fill!The Jeep has several 'hook points' on the storage area-- 2 d-rings on each side, 4 anchor points in the floor, and lots of other good places to hook. When we travel with our dogs, they are very much appreciated to lash cargo safely to the side (leaving the center area open for dogs) in case of an avoidance maneuver, etc. I use 2 nylon webbed anchor straps and the occasional bungee cord to keep things in place. This, while it may seem like a little thing, is a huge convenience! SO, if the 'cargo management' system is as described, the obvious question is this: ARE there hook points in the Edge or MKX? Little things make a huge difference. At this point, I'm going to have a hard time letting go of the Jeep! No hook points in our 2007 SEL+ (that I recall, anyway). You can, though, add a Cargo Logic organizer available through Ford Accessories. The Cargo Management system is really nothing more than a molded insert that goes around the spare tire, which is located below the cargo area floor. You can put some small items in the Cargo Management partitions, but nothing of any size. Quote Link to comment Share on other sites More sharing options...
