Can send but not receive cell calls.
I have a 2010 Edge. I haven't had any problems with the sync until a few days ago. While driving, my cell phone and the sync began to ring. I pressed the 'phone' button on the steering wheel like I have done in the past to connect, but the cell phone did not connect with the sender. I have to press the receive button on the cell phone in order to connect with the caller. I can send calls through sync by giving voiice commands without any problems. What can be done? Thanks.
I can remove/replace phone battery without any problems...but do I have to do the whole deleting/pairing routine for your second suggestion?
As a Sync Specialist i would make sure the button on the steering wheel is actually working. Try pushing the button
to see if you get something on the screen like redial. I really dont think its a phone problem unless its a phone that
has an operating system like the i phone or droid. In this case just like windows they have to be rebooted just like
windows or they start to act up. Also go into your sync account and make sure there are no updates. Let me know if
you need more help.
you need more help.
I have Sync Version Gen. 1-v3.1 installed on my vehicle. I did remove/install my cell battery and I was able to connect with an incoming call...perhaps I pushed the "phone" button on the steering wheel differently or it might have been a coincidence remains to be seen. Hopefully, it will continue to work. Thanks for your suggestions.
Edited by bigalx58
you need more help.
Hi Ladybird4,
Got my wife a Iphone 2 weeks ago, paired it to her '09 MKS & my '12 MKX. Set as favorite in her car, all is fine. She took the MKX out yesterday, tried to connect her Iphone, she said it would not connect. I haven't had a chance to check things out, her sister in the hospital, and she's been running back and forth. Any suggestions on what to do would be appreciated.
Thanks,
Joe
Edited by JOEHIO
1330486594[/url]' post='73794']
Hi Ladybird4,
Thanks,
Joe
Joe, the odd time my I4 won't pair either. Happens maybe one in 50 times. Next time I start it, all is good.
Sounds like a setting problem to me. I have paired many I Phones and the only problem i have run into
is people not shutting the phone down every couple of days. Make sure blue tooth did not get turned off in the
car or on the phone. Keep us updated and i will figure it out for you.
Thanks Richy & Ladybird4, will have to give it a try when the wife gets back home. Her sister was released from the hospital today, nothing more they can do (has battled a very aggresive cancer for 19 months), so my wife is there 24/7 until the weekend, when her sons "fill in". Will try your suggestions when she gets back home.
Joe
