Keypad code programming
Now this isn't in regards on how to do it from the keypad itself as I was able to do that. But I noticed in the settings on the MFT that you could set a code from there. Now it tells you to input the factory keypad code, which I did, and then hit enter. I did this and nothing happened, didn't recognize it or anything. So I guess my question is, has anyone got this to work? I was able to set a new code from the keypad using that same factory code so not sure why it's not working there, unless I am totally mixing this up and it is something else, haha.
