Swapping "one auto" for "all auto" on the window switches
Got a 2011 SEL and love it. Besides the bugginess of MFT, I'm mildly irked by only one thing: The driver's side power window switches. My SEL has the "one auto" configuration and my 2001 Lexus had "all auto."
It is my understanding that the "all auto" option is available, but has anybody swapped this out? Is it a simple part swap? I'd love some input.
Thanks in advance.
Peace,
DM
not possible unfortunately. on older vehicles it was because all you had to do was add auto down relays to the up switch
this is probably what you are referring to :
The glass, frames and mechanisms include the following:
Edge
  • Standard power windows, including one-touch up and one-touch down (LH front window only)
MKX
  • Standard power windows, including one-touch up and one-touch down (LH and RH front windows only)
    Global Open — MKX Only
    NOTE: The global open feature may be enabled/disabled via scan tool or in some cases modified by the customer following a procedure listed in the Owner's Literature. For a complete list of available programmable parameters, refer to the Module Configuration and Parameter Chart in Section 418-01.
    NOTE: If the accessory delay relay is active, the global open feature does not operate.
    When a request is received from the Remote Keyless Entry (RKE) transmitter, the BCM sends a signal on the global open circuit to both front door window motors (to open the windows) and to the roof opening panel (if equipped; to open the roof opening panel).
Edited by FordGuru
