d94 Posted February 21, 2012 Report Share Posted February 21, 2012 Can someone tell me the order of the cylinders on the 3.5L or point me to a diagram. I can't find any info on the internet. Thanks Quote Link to comment Share on other sites More sharing options...
FordGuru Posted February 21, 2012 Report Share Posted February 21, 2012 Can someone tell me the order of the cylinders on the 3.5L or point me to a diagram. I can't find any info on the internet. Thanks standing in front of the vehicle with hood up looking towards back of vehicle 1 2 3 O O O ---------- O O O 4 5 6 Quote Link to comment Share on other sites More sharing options...
d94 Posted February 21, 2012 Author Report Share Posted February 21, 2012 standing in front of the vehicle with hood up looking towards back of vehicle 1 2 3 O O O ---------- O O O 4 5 6 So to confirm this, 1 and 4 are on the passenger's side and 3 and 6 on the driver's side? I guess this means my misfire on 2 would be the one that is buried at the back not the easily accessible ones at the front. That figures. Thanks Quote Link to comment Share on other sites More sharing options...
FordGuru Posted February 21, 2012 Report Share Posted February 21, 2012 So to confirm this, 1 and 4 are on the passenger's side and 3 and 6 on the driver's side? I guess this means my misfire on 2 would be the one that is buried at the back not the easily accessible ones at the front. That figures. Thanks correct. Quote Link to comment Share on other sites More sharing options...
REDSPORT Posted September 29, 2017 Report Share Posted September 29, 2017 I just had an issue today with a cylinder misfire on my 2010 Edge Sport. The misfire was number six and i had just installed new motor craft spark plugs. I assumed it was the coil pack then. After installing the coil pack, there was no change. I moved the Spark plug from position 6 to 5 and that became the cylinder misfiring so obviously it was a bad spark plug. I replaced the plug and the problem was solved. I should have replaced the plug first since now i have a new coil pack I didn't really need. However i am approaching 170,000 Kms and coil packs tend to go at 180,000 Kms so i have a spare for now. Quote Link to comment Share on other sites More sharing options...
addisonm06 Posted September 29, 2017 Report Share Posted September 29, 2017 If you havnt yet, replace all the plugs! Right around 102k i had a misfire on cyclinder 6 that actually cracked the coil pack and backfed into the pcm. I changed just than pack and plug and 3 months later, a misfire on 3. I changed all the plugs; packs looked fine and luckily didnt cause more damage. If 1 of the cylinders is misfiring from a plug/coil... it is time! You are on borrowed time before another issue, and it may be more catastrophic! I cannot urge enough, replace all the plugs. 1 Quote Link to comment Share on other sites More sharing options...
