Derelique Posted February 21, 2012 Report Share Posted February 21, 2012 (edited) Thought I would post my findings on my Edge. I had a PAC line converter going to my stock head unit with the remote turn on built into the PAC unit. I was getting popping noises from my sub when the amp would turn off. It was very frustrating and searched for days for a ACC or power antenna wire. Anyways, in the 2011 it is pin # 2(see attached). I am guessing the 2012 are the same, although you should test the wire before you do anything. Hopefully this helps some of you. Edge ACM.pdf Edited February 21, 2012 by Derelique Quote Link to comment Share on other sites More sharing options...
MKXJames Posted April 16, 2012 Report Share Posted April 16, 2012 Where do you hook the remote wire for your amp to? Quote Link to comment Share on other sites More sharing options...
