How to remove stock gas cap from fuel door?
DunePearlEdge
I have an 07 edge which I just recently purchased a locking gas cap for. The stock gas cap is attached to the fuel flap arm with a plastic line and expanding grommet. What is the proper way to push this grommet backwards through the hole in the fuel filler arm? I tried pushing with a screwdriver and pliers (not too hard because I don't want to break anything) but had no luck. Have any of you successfully removed this without damaging it?
