Eddie P Posted February 1, 2012 Report Share Posted February 1, 2012 (edited) Our 2008 Edge stopped running today. It's at the shop now, I'm just doing a little thinking and was wondering if this was an interference or non-interference engine? Sort of a worst case scenario type of thinking... BTW, my apology if this has been asked or covered before. I looked but couldn't find the answer. Thanks in advance, Eddie Edited February 1, 2012 by Eddie P Quote Link to comment Share on other sites More sharing options...
flyerjmr33 Posted February 1, 2012 Report Share Posted February 1, 2012 (edited) Our 2008 Edge stopped running today. It's at the shop now, I'm just doing a little thinking and was wondering if this was an interference or non-interference engine? Sort of a worst case scenario type of thinking... BTW, my apology if this has been asked or covered before. I looked but couldn't find the answer. Thanks in advance, Eddie It doesn't use a timing belt, so it makes no difference-- the Edge uses a timing chain. Edited February 1, 2012 by flyerjmr33 Quote Link to comment Share on other sites More sharing options...
akirby Posted February 2, 2012 Report Share Posted February 2, 2012 It doesn't use a timing belt, so it makes no difference-- the Edge uses a timing chain. Even timing chains can break so it does make a difference - although I doubt that's the problem in this case. Could be a crankshaft position sensor. Quote Link to comment Share on other sites More sharing options...
flyerjmr33 Posted February 2, 2012 Report Share Posted February 2, 2012 Even timing chains can break so it does make a difference - although I doubt that's the problem in this case. Could be a crankshaft position sensor. I spent 35 years in the automotive business and never once saw a BROKEN timing chain--- I've seen many that have stretched and skipped a couple of teeth where the engine would not run--- but NEVER a broken one--- Quote Link to comment Share on other sites More sharing options...
akirby Posted February 3, 2012 Report Share Posted February 3, 2012 I spent 35 years in the automotive business and never once saw a BROKEN timing chain--- I've seen many that have stretched and skipped a couple of teeth where the engine would not run--- but NEVER a broken one--- I had a 75 cutlass that wouldn't start and I was told the timing chain broke. Maybe it only slipped a little. But I assume it is possible if rare. Quote Link to comment Share on other sites More sharing options...
flyerjmr33 Posted February 3, 2012 Report Share Posted February 3, 2012 I had a 75 cutlass that wouldn't start and I was told the timing chain broke. Maybe it only slipped a little. But I assume it is possible if rare. Did they show you a broken chain??? More than likely, what broke was that nylon drive gear on the camshaft--- But, I'll bet it happened when you shut it down and tried to start it again. Quote Link to comment Share on other sites More sharing options...
akirby Posted February 3, 2012 Report Share Posted February 3, 2012 Did they show you a broken chain??? More than likely, what broke was that nylon drive gear on the camshaft--- But, I'll bet it happened when you shut it down and tried to start it again. Probably. Thanks for the clarification. Quote Link to comment Share on other sites More sharing options...
