JOYRIDER Posted January 31, 2012 Report Share Posted January 31, 2012 Just installed The Retrofit Source Elite 9006 HID Kit in my '11 Limited. Being 9006 bulbs I did have to trim one tab on each bulb to fit in the OEM housings. That said, I believe the 'bar' that runs along the outside of the bulb is on the underside (or the top, I can't remember ) of the bulb, which is my best guess as to what's causing this? Problem is the bulbs seem to only go in one way and it was a bitch to get them in at all frankly, so I'm not sure it's as simple as 'just rotate them a little'. Fixes? From 13 feet away From 25 feet away From 25 feet away Quote Link to comment Share on other sites More sharing options...
JOYRIDER Posted February 1, 2012 Author Report Share Posted February 1, 2012 For the record, the 9006 bulbs in this kit, even with trimming, WILL NOT FIT 2011+ FORD EDGE correctly. The return wire shadow is a problem and is not solved by rotating the bulb. After hours of trying to make this work and calls with The Retrofit Source they simply said "We've made a note that this kit will not work with 2011+ Edges or Explorers." I'm stuck with removing the installed kit, holes in the back of my bulb covers and the cost of return shipping on a "premium, quality" product that they obviously didn't do their due diligence on before recommending it for our trucks. Lovely. Quote Link to comment Share on other sites More sharing options...
richy Posted February 2, 2012 Report Share Posted February 2, 2012 I'd make a big stink about having to pay return shipping. Tell them you'll hire a lawyer to sue them for your labour costs, etc. The squeaky wheel always gets the grease. Keep going up their company ladder till you get the answer you want! Quote Link to comment Share on other sites More sharing options...
Edge_Beast Posted February 2, 2012 Report Share Posted February 2, 2012 Well that sucks. Weird on how my ddm 9006 fits fine. No problems. Quote Link to comment Share on other sites More sharing options...
josegt Posted February 3, 2012 Report Share Posted February 3, 2012 I have the same kit from The Retrofit Source, and also the same issues. The kit was a bitch to install (pardon my french). My wife helped me, because I have big hands. I´m going to install my other option, the one from Retro solutions 55 watt 9012 kit, the 35 watt output just don't work with this truck's single light. I'm considering to put auxiliary lights, I'll post pictures with my project. Quote Link to comment Share on other sites More sharing options...
