Keesesp Posted January 27, 2012 Report Share Posted January 27, 2012 I have snaked the (+) 12guage wire from the relay box(By the driver's rear taillight grommet), down the driver side wallcovers and carpet molding. To behind the driver's kick plate(Just above the fusebox) and coiled the (+)wire on top of the fusebox. I need to find a way into the engin compartment,to connect a fused wire to the battery. Any Ideas? Thank You for your help. Steven K. Quote Link to comment Share on other sites More sharing options...
dr.edge Posted January 27, 2012 Report Share Posted January 27, 2012 I have snaked the (+) 12guage wire from the relay box(By the driver's rear taillight grommet), down the driver side wallcovers and carpet molding. To behind the driver's kick plate(Just above the fusebox) and coiled the (+)wire on top of the fusebox. I need to find a way into the engin compartment,to connect a fused wire to the battery. Any Ideas? Thank You for your help. Steven K. There is a good sized grommet/rubber boot that seals the steering column as it goes through the firewall. Push it through there from the inside into the engine compartment and then pull it through to the battery. Quote Link to comment Share on other sites More sharing options...
Keesesp Posted January 28, 2012 Author Report Share Posted January 28, 2012 Dr. Edge!! You are the BOMB!! Thank You!! Quote Link to comment Share on other sites More sharing options...
Dingo Posted January 28, 2012 Report Share Posted January 28, 2012 Yeah, I ran all the radar detector wires through the bottom of it. Quote Link to comment Share on other sites More sharing options...
Keesesp Posted January 28, 2012 Author Report Share Posted January 28, 2012 Yeah, I ran all the radar detector wires through the bottom of it. AWESOME!! Quote Link to comment Share on other sites More sharing options...
