swalker Posted January 23, 2012 Report Share Posted January 23, 2012 Hello. I have a 2011 Edge and for the last month or so I have noticed the 7/8 on the key pad will light up sometimes and be out other times. I'm assuming bad part or connection. I need to get it in so the dealer can fix this under warranty but was just curious if anyone else has run into this before. Thanks! Quote Link to comment Share on other sites More sharing options...
bbf2530 Posted January 23, 2012 Report Share Posted January 23, 2012 On 1/23/2012 at 2:11 PM, swalker said: Hello. I have a 2011 Edge and for the last month or so I have noticed the 7/8 on the key pad will light up sometimes and be out other times. I'm assuming bad part or connection. I need to get it in so the dealer can fix this under warranty but was just curious if anyone else has run into this before. Thanks! Hi swalker. :D Yes, it happens. Like any part/component, there will always be a small failure rate. Let us know how you make out and good luck. :beerchug: Quote Link to comment Share on other sites More sharing options...
