jlpdp9 Posted January 4, 2012 Report Share Posted January 4, 2012 Has anyone purchased the sct tuner from Steeda and used it. I would like to know if you noticed a difference and if it came with the three tunes. Ive had the Steeda intake for a few months now and want the tuner so i can take out the restrictor any suggestions? Quote Link to comment Share on other sites More sharing options...
RJG Posted January 8, 2012 Report Share Posted January 8, 2012 (edited) On 1/4/2012 at 2:52 AM, jlpdp9 said: Has anyone purchased the sct tuner from Steeda and used it. I would like to know if you noticed a difference and if it came with the three tunes. Ive had the Steeda intake for a few months now and want the tuner so i can take out the restrictor any suggestions? Well.....You've only got two things to work with. Timing and A/F ratio. By intake I assume you mean cold air kit. I think of intake as something else. You can maybe add some timing, requiring use premium fuel, either add some fuel with SCT tuner, or lean it a tad for more power. No mystery. Tuner plus your cold air kit might add 5-10 HP at max RPM. No change really in mid range my guess. Edited January 8, 2012 by RJG Quote Link to comment Share on other sites More sharing options...
