SCT tuner 07 edge
jlpdp9
Has anyone purchased the sct tuner from Steeda and used it. I would like to know if you noticed a difference and if it came with the three tunes. Ive had the Steeda intake for a few months now and want the tuner so i can take out the restrictor any suggestions?
Well.....You've only got two things to work with. Timing and A/F ratio. By intake I assume you mean cold air kit. I think of intake as something else.
You can maybe add some timing, requiring use premium fuel, either add some fuel with SCT tuner, or lean it a tad for more power. No mystery. Tuner plus your cold air kit might add 5-10 HP at max RPM. No change really in mid range my guess.
Edited by RJG
