2011 Edge Limited - HVAC Heat - No in between
I noticed a couple months ago that the HVAC temperature does not seem to work or mix the hot and cold. I brushed it off my shoulders until today when I was on a 4+ hr car ride. It was cold outside so I put the heat on but it obviously got too hot so I put the temperature down to around 75 degrees (from HI) and the temp was still the same. I continued to lower the temp until i got to 65 degrees and it was still blazing hot. If i shut the HVAC off the turn it back on then the temp would cool down.
AC works fine, Heat works fine but there is no in between... Has anybody else noticed this or hear of this happening before?
