vdaily89 Posted December 18, 2011 Report Share Posted December 18, 2011 I had disconnected the battery on my Edge with the CD6 changer. The changer was full. Now I get "CD error" or "Initializing" and the player won't work. Is there any way to get the CD's out so I can get it to work? Thanks Quote Link to comment Share on other sites More sharing options...
ThirdDJ Posted February 21, 2012 Report Share Posted February 21, 2012 I had an identical issue. My Edge is sadly out of warranty and so to fix the problem at the dealership would have cost 365 dollars. No thanks. Instead, I simply took the radio out, removed the 6 CD changer from the housing, took my CD's out, and tried finding the problem. No dice. The CD changer was kaput. So I kept the changer out of the housing but put everything back into place in the car. Every still works now except the CD player. Good thing I have a hard drive.... Quote Link to comment Share on other sites More sharing options...
CHANCES Posted September 19, 2016 Report Share Posted September 19, 2016 Same thing happened to me after getting a jump start a few months ago. CDs still stuck in it.. Told that it will cost hundreds to fix..insane, they need to fix this problem. not fair Quote Link to comment Share on other sites More sharing options...
Jburridge Posted September 21, 2016 Report Share Posted September 21, 2016 How do you reset the CD player in a 2008 Ford Edge SEL after replacing battery. Quote Link to comment Share on other sites More sharing options...
enigma-2 Posted September 21, 2016 Report Share Posted September 21, 2016 (edited) I don't believe that there is a reset button (of sorts). You might try an electrical reset. Pull the owner's manual out & look up fuse box chart to identify the one(s) that affect your radio/cd changer. Turn the key to ACC setting & turn on radio. Open the fuse box & pull all relevant fuses. Radio should quit. Then turn the key off & then reinsert the fuses. Turn the key back to ACC and turn on the radio. If this works, you should then be able to eject your cds. If this doesn't work, the only other option I know of, is to remove the radio and remove the top cover (one screw I believe). You can then wiggle the cds to get them back on position. I believe what hapens is, when the the battery dies, the changer starts shuffling through discs and causes one disc to pop out of it's slot; and jam inside the unit. Causes a "no disc" error when trying to play a cd and "load error" when trying to eject/insert a disc. Edited September 21, 2016 by enigma-2 Quote Link to comment Share on other sites More sharing options...
