puddleman Posted March 8, 2016 Report Share Posted March 8, 2016 just changed mine at 100k miles the factory when they came out were gapped at 130,000ths new NGK iridium IX and mpg in town is up 3mpg. the intake removal was straight forward with no guides or help but this wasnt my first time with a badly designed upper end to an engine. 1 Quote Link to comment Share on other sites More sharing options...
IWRBB Posted March 9, 2016 Report Share Posted March 9, 2016 Those NGK IX irriduims are great plugs. I put them in everything. Quote Link to comment Share on other sites More sharing options...
dre2142 Posted April 25, 2016 Report Share Posted April 25, 2016 I did the above and have slight feedback/vibration at 1800rpms.... any ideas of what could be causing this?Only issue I ran into was getting my rear boots off- had to end up replacing them as they cracked/broke on the way out. Kinda a panic moment on how to get them out but ended up using a hook tool to grab them and bring them out. Easy in the end. Quote Link to comment Share on other sites More sharing options...
HackerF15E Posted August 1, 2016 Report Share Posted August 1, 2016 Anyone also replace their coils while they had the intake off and were doing the plugs? Quote Link to comment Share on other sites More sharing options...
WWWPerfA_ZN0W Posted August 1, 2016 Report Share Posted August 1, 2016 I did. Quote Link to comment Share on other sites More sharing options...
roadrage Posted April 25, 2017 Report Share Posted April 25, 2017 I am due for the plug replacement, coolant flush and pcv replacement as well. When getting quotes for the labor (I have all the parts sitting at home), one shop recommended I change the intake manifold gasket when doing the plugs. Is this normal? I asked a service worker at the dealer and said they don't normally replace the gasket, however it is recommended. Please share your thoughts on this. Quote Link to comment Share on other sites More sharing options...
macbwt Posted April 28, 2017 Report Share Posted April 28, 2017 On 4/25/2017 at 2:58 PM, roadrage said: I am due for the plug replacement, coolant flush and pcv replacement as well. When getting quotes for the labor (I have all the parts sitting at home), one shop recommended I change the intake manifold gasket when doing the plugs. Is this normal? I asked a service worker at the dealer and said they don't normally replace the gasket, however it is recommended. Please share your thoughts on this. I have almost 200k miles on the original intake gasket. You do not really need to change it but the price for the gaskets is pretty cheap so why not change them since you are in there. By the way I am doing a Facebook live spark plug change on a 2011 Ford Edge on MACTFORDEDGE on Facebook. This Saturday 29 April 2017 in the AM. 2 Quote Link to comment Share on other sites More sharing options...
autom8r Posted April 28, 2017 Report Share Posted April 28, 2017 Upper intake manifold gasket, there's a lower one too. They are pretty durable. If this is your first change out, you probably don't need to. I changed mine on my second set. Use a torque wrench so you don't overdo it. 2 Quote Link to comment Share on other sites More sharing options...
tommy salcedo Posted December 2, 2017 Report Share Posted December 2, 2017 I was able to replace my plugs, PCV, and manifold thanks to @macbwt's video. The Edge is a little tighter than the Explorer, had to take the throttle body off (4 bolts) to get access to the manifold bracket bolt, and get enough clearance to snake that thing out of the harness. Also on the Edge, the wiring harness that crosses is tough--I was unsuccessful getting the plastic brackets out (I figured I would break them if I fiddled any more) so I slid the harness out. What is holding them to the bracket is electrical tape (!) slid in to the sides. If you loosen the bracket enough, you can wiggle the harness out of the holding. A well-lit look into the back side of the brackets will give away what's holding on. Thanks everyone. 3 Quote Link to comment Share on other sites More sharing options...
thegeoguy Posted February 2, 2018 Report Share Posted February 2, 2018 Great writeup! I will be doing this next week on my 2008 Ford Edge with 115k miles on the clock and I can only assume the spark plugs are original (I bought it 3 years ago at 96k) Ill be swapping the intake gaskets and PCV valve too while im in there. Thanks for the 11 lb/ft torque spec it was hard to find on google. 1 Quote Link to comment Share on other sites More sharing options...
macbwt Posted February 14, 2018 Report Share Posted February 14, 2018 quick spark plug change during your lunch break. 1 Quote Link to comment Share on other sites More sharing options...
cincyedge13 Posted July 23, 2018 Report Share Posted July 23, 2018 Hello everyone. Newby here. I appreciate all of the info and am trying to tackle the spark plug change myself after my dealer told me it was a 4 hr job and would run me $528. (Local mechanic, whom I like and trust, told me it was 3 hr job and would be "at least" $400.) The issue I'm currently having as I try and get up to speed on the job is that none of the pics from this site will download. (I'm most interested in the PDFs in the OG post in this thread). I'm getting either an error message from the forum saying "something went wrong" and the "images aren't available" and/or a "blocked" message from my security software saying that the download contained a virus. If anyone could advise me on this, I would appreciate it. 1 Quote Link to comment Share on other sites More sharing options...
1004ron Posted July 23, 2018 Report Share Posted July 23, 2018 On 7/23/2018 at 2:02 PM, cincyedge13 said: Hello everyone. Newby here. I appreciate all of the info and am trying to tackle the spark plug change myself after my dealer told me it was a 4 hr job and would run me $528. (Local mechanic, whom I like and trust, told me it was 3 hr job and would be "at least" $400.) The issue I'm currently having as I try and get up to speed on the job is that none of the pics from this site will download. (I'm most interested in the PDFs in the OG post in this thread). I'm getting either an error message from the forum saying "something went wrong" and the "images aren't available" and/or a "blocked" message from my security software saying that the download contained a virus. If anyone could advise me on this, I would appreciate it. https://www.fordedgeforum.com/topic/24544-since-the-forum-updateupgrade-the-recent-topics-is-not-updating/page-2?do=findComment&comment=188107 Maybe an issue with the recent update/upgrade. 1 Quote Link to comment Share on other sites More sharing options...
WWWPerfA_ZN0W Posted July 24, 2018 Report Share Posted July 24, 2018 (edited) Let's see if these files work Ford Edge & Lincoln MKX SPARK PLUG replacement.pdfFetching info... 3.5L sparkplug1.pdfFetching info... 3.5L sparkplug2.pdfFetching info... 3.5L sparkplug3.pdfFetching info... 3.5L sparkplug4.pdfFetching info... 3.5L sparkplug5.pdfFetching info... 3.5L sparkplug6.pdfFetching info... 3.5L sparkplug7.pdfFetching info... 3.5L sparkplug8.pdfFetching info... Edited July 24, 2018 by WWWPerfA_ZN0W Quote Link to comment Share on other sites More sharing options...
WWWPerfA_ZN0W Posted July 24, 2018 Report Share Posted July 24, 2018 (edited) MKX plug replacement - single file version 3.5L sparkplug change on a 2007 MKX.pdfFetching info... Edited October 17, 2018 by WWWPerfA_ZN0W 1 Quote Link to comment Share on other sites More sharing options...
cincyedge13 Posted July 27, 2018 Report Share Posted July 27, 2018 That did it! I was able to download and view the PDFs without issue. As others have stated, they are fantastic. Thanks for the help! I'll chime in after the plug change to let everyone know how it went. 1 Quote Link to comment Share on other sites More sharing options...
cincyedge13 Posted October 17, 2018 Report Share Posted October 17, 2018 Update: I consider myself pretty handy, but after starting on the plug change and having some difficulty removing one of the hoses (and then getting confused figuring out what was what based on the instructions on here and on youtube), I got cold feet and backed off. I called a buddy who is a mechanic and he said he would come over and help me with it if I gave him some cash, so that's what we did. He made it look easy. He didn't even want to use the torque wrench; told me it would be pretty tough to get the plugs too loose or too tight and he had done so many of them that he could snug them by feel. Okaaaay. Took him about an hour to do the whole thing. I asked him why the shop said it would take so long, and he said that they just always over-estimate, that way if it ends up taking longer for some reason, they are covered. He said they do the same thing at his shop too. Anyway, I have new plugs now (Edge is running great) and I saved a couple hundred dollars without the fear of screwing up the job. Bottom line: this job isn't a cake walk, and there are things you could screw up big time if you don't know what you are doing. And the way things look under the hood may not match the instructions you find online, as I came to find out. My advice would be to know your limits and proceed with caution. 1 Quote Link to comment Share on other sites More sharing options...
WWWPerfA_ZN0W Posted October 17, 2018 Report Share Posted October 17, 2018 And have a buddy who is a good mechanic Quote Link to comment Share on other sites More sharing options...
1004ron Posted October 17, 2018 Report Share Posted October 17, 2018 On 7/24/2018 at 3:56 AM, WWWPerfA_ZN0W said: MKX plug replacement - single file version Looks like the forum is still screwed up !!!! Get this error message when attempting to download the PDF. Quote Oops! Something went wrong! [#10173] We could not find the attachment you were attempting to view. Need Help? Our help documentation Contact the community administrator Quote Link to comment Share on other sites More sharing options...
WWWPerfA_ZN0W Posted October 17, 2018 Report Share Posted October 17, 2018 Yup sure looks like it. A periodic sweeper routine perhaps? Anyhoo, updated the post, should work ... for now ... Quote Link to comment Share on other sites More sharing options...
Bfazona Posted October 17, 2018 Report Share Posted October 17, 2018 Prob the right move, Cincy. While the plug swap is pretty straight forward, that is the case for people that have turned a wrench or two. I work on all my own vehicles and thought the Edge was more time consuming, but not complex considering you need to remove the plastic intake. I like the rubber gaskets Ford chose and ease of reaching the bolts. Definitely more involved than most plug swaps though and glad you had a friend help to save some cash. Quote Link to comment Share on other sites More sharing options...
Gmandude Posted June 5, 2020 Report Share Posted June 5, 2020 On 2/14/2018 at 3:26 AM, macbwt said: quick spark plug change during your lunch break. Expand I loved this video. It took me much long although I have a 2.7LTT AWD Quote Link to comment Share on other sites More sharing options...
luckylibra23@icloud.com Posted September 17, 2021 Report Share Posted September 17, 2021 Can someone please assist me as how I should open the PDF to view, I’ve download it and it’s saying 0KB! Trying to change my spark plugs at the moment Quote Link to comment Share on other sites More sharing options...
1004ron Posted September 17, 2021 Report Share Posted September 17, 2021 Your browser should be able to open the PDF, or download it and open with Adobe or other app. 3.5L sparkplug change on a 2007 MKX.pdf Quote Link to comment Share on other sites More sharing options...
Judd83 Posted August 4, 2024 Report Share Posted August 4, 2024 (edited) I just did the same thing. Do you have a wiring diagram for this 2 wire plug on the back of the intake? Does it really matter which one goes on which side? Are they Polarity sensitive? Thanks Edited August 4, 2024 by Judd83 Quote Link to comment Share on other sites More sharing options...
