epsanto2 Posted December 1, 2011 Report Share Posted December 1, 2011 The center front console seems awfully deep and my wife was going to cut some foam to put in the bottom so things were not so hard to reach. I told her either 1) grow some real arms or 2) I would look for a unit we seen advertised for the GMC Yukon called a console organizer that made it a two tier system. I presume it is merely a lift out tray that allows one to store larger items in the bottom and smaller, more frequently used items in the top. Does anybody know of such a critter existing for the Edge? Thanks Quote Link to comment Share on other sites More sharing options...
dr.edge Posted December 1, 2011 Report Share Posted December 1, 2011 The center front console seems awfully deep and my wife was going to cut some foam to put in the bottom so things were not so hard to reach. I told her either 1) grow some real arms or 2) I would look for a unit we seen advertised for the GMC Yukon called a console organizer that made it a two tier system. I presume it is merely a lift out tray that allows one to store larger items in the bottom and smaller, more frequently used items in the top. Does anybody know of such a critter existing for the Edge? Thanks I haven't seen anything commercially available but check out this thread for a DIY solution. This is what I've done and it works pretty well. Quote Link to comment Share on other sites More sharing options...
rwolson Posted December 1, 2011 Report Share Posted December 1, 2011 I haven't seen anything commercially available but check out this thread for a DIY solution. This is what I've done and it works pretty well. Ah, good, I see you found the thread before me. Great thread with many good ideas. Quote Link to comment Share on other sites More sharing options...
epsanto2 Posted December 2, 2011 Author Report Share Posted December 2, 2011 I haven't seen anything commercially available but check out this thread for a DIY solution. This is what I've done and it works pretty well. Great solution... functional, simple, and like tonights dinner, can be made from leftovers. Thanks for directing me there. Quote Link to comment Share on other sites More sharing options...
