milosm Posted November 28, 2011 Report Share Posted November 28, 2011 I would like to lower the my edge about 2" , it would help my wife get in .does anyone know of a 3rd party kit I could install, and what would it take? Doug. Quote Link to comment Share on other sites More sharing options...
wilsons66604 Posted November 28, 2011 Report Share Posted November 28, 2011 I would like to lower the my edge about 2" , it would help my wife get in .does anyone know of a 3rd party kit I could install, and what would it take? Doug. Just a thought....In my Limited, I can lower my seats. Have you lowered your seats? The lower seats do make it a bit easier to get in. Quote Link to comment Share on other sites More sharing options...
dr.edge Posted November 29, 2011 Report Share Posted November 29, 2011 I would like to lower the my edge about 2" , it would help my wife get in .does anyone know of a 3rd party kit I could install, and what would it take? Doug. Most aftermarket kits (either H&R or Eibach) will lower the car by about 1/2" to 3/4". Trying to lower it by 2" is a lot to compensate for - tires, wheel wells, suspension settings, etc. You're definitely in race mode at that point. Quote Link to comment Share on other sites More sharing options...
Dingo Posted November 29, 2011 Report Share Posted November 29, 2011 I put the H&Rs on mine and it's more of a drop than that. Quote Link to comment Share on other sites More sharing options...
wlepse Posted November 29, 2011 Report Share Posted November 29, 2011 http://www.tirerack.com/suspension/Susptabl.jsp?autoMake=Ford&autoModel=Edge+Limited&autoYear=2011&autoModClar=AWD Eibach 1.7" in front and 1.3 in th rear H&R 1.75" front 1.5" rear Unless you have a bunch of tools and have done this sort of thing before I would recommend going to a shop. Most shops will charge about 300-400 to install plus you'll need to get an alignment check. Quote Link to comment Share on other sites More sharing options...
Dingo Posted November 29, 2011 Report Share Posted November 29, 2011 Unless you have a bunch of tools and have done this sort of thing before I would recommend going to a shop. Most shops will charge about 300-400 to install plus you'll need to get an alignment check. I did mine, but I have a bunch of tools and have done this sort of thing before. It's a lot easier than I had anticipated, but I agree that if you think you might not be able to do it, don't try. Take it to a shop. An an alignment is most definitely needed. Quote Link to comment Share on other sites More sharing options...
wilsons66604 Posted November 29, 2011 Report Share Posted November 29, 2011 I would like to lower the my edge about 2" , it would help my wife get in .does anyone know of a 3rd party kit I could install, and what would it take? Doug. How about running boards? Those may help. Quote Link to comment Share on other sites More sharing options...
wlepse Posted November 29, 2011 Report Share Posted November 29, 2011 Maybe it is just me but I find running boards on a vehicle this size to be more problems. Seems like teh running boards don't stick out enough for most people to realize they are there and when they step past them they often don't completely clear them so all the road grime ends up on you clothes. Maybe it is just the ones I saw but if you go that route definitely try to find someone local with them to check them out. Quote Link to comment Share on other sites More sharing options...
milosm Posted November 29, 2011 Author Report Share Posted November 29, 2011 (edited) Thanks for all the info I now have a lot to think about, and if its worth all the work. Doug. Edited November 29, 2011 by milosm Quote Link to comment Share on other sites More sharing options...
dr.edge Posted November 29, 2011 Report Share Posted November 29, 2011 http://www.tirerack....autoModClar=AWD Eibach 1.7" in front and 1.3 in th rear H&R 1.75" front 1.5" rear Unless you have a bunch of tools and have done this sort of thing before I would recommend going to a shop. Most shops will charge about 300-400 to install plus you'll need to get an alignment check. Geez, you're absolutely right - I must have lost an inch somewhere. Anyone have any experience (good or bad) with one brand over the other? I would think they're pretty much identical, they're just springs, right? Quote Link to comment Share on other sites More sharing options...
ARBO Posted July 10, 2012 Report Share Posted July 10, 2012 I want to lower my 2011 Limited AWD. Do I just need the springs, or do I need camber bolts to bring it into alignment? i have a friend that lowers tons of Mustangs (3 of mine) just wondering about issues with alignment or AWD. And how is the ride? Quote Link to comment Share on other sites More sharing options...
