wlepse Posted November 26, 2011 Report Share Posted November 26, 2011 I currently have a 320GB USB drive with about 60GB of music in the Edge that seems to be working fine, except for the occasional "usb device not recognized" message from MFT. But I am concerned about the long term durability of a standard drive with the temp extremes. I was thinking about doing a flash drive but 64GB drives are rediculously priced. Since there have been a ton of 32GB drives selling cheap lately I was wondering if I could get a cheap USB hub and plug a couple of flash drives in. But I am not sure if the car will see all the drives simultaneously or if I would need to pick which drive I want to use. Does anyone have experience with multiple USB devies? When you go to browse do you see all artists or just the ones on a particular flash drive? Either way I was going to use the extra USB connector on the APIM and hide all of this in the center console. Quote Link to comment Share on other sites More sharing options...
Dingo Posted November 27, 2011 Report Share Posted November 27, 2011 You can use 2 devices. It labels them USB1 and USB2. Browse only goes through whichever source you have active at that time. Quote Link to comment Share on other sites More sharing options...
wlepse Posted November 27, 2011 Author Report Share Posted November 27, 2011 Really...I thought I read somewhere here that there are two USB connectors on the APIM but only one is connected and the other connection was USB2?? I did a search for a RAID USB device but it only seems to be possible with software nothing hardware based. So I guess I'll stick with my external drive and when it craps out maybe the prices of 64GB flash drives will be reasonable or I'll get an SSD. Quote Link to comment Share on other sites More sharing options...
Dingo Posted November 27, 2011 Report Share Posted November 27, 2011 The external drive I bought is supposedly everythingproof. Quote Link to comment Share on other sites More sharing options...
4havnfun Posted November 27, 2011 Report Share Posted November 27, 2011 Shortly after I started dealing with MFT I was trying to browse music on my iPod and at one point MFT thought I had more than 2 USB devices connected. I didn't and it hasn't done it since but this leads me to believe that if you tried a USB hub it would probably work. Quote Link to comment Share on other sites More sharing options...
Dingo Posted November 27, 2011 Report Share Posted November 27, 2011 I would try, but I have no hub. Quote Link to comment Share on other sites More sharing options...
wlepse Posted November 27, 2011 Author Report Share Posted November 27, 2011 I only have powered hubs right now, but I'll check with my co-worker he might have something. He might even be able to add something on the USB RAID setup....as I was searching this out I found a tech article on his site. But if I can't find it easily it will likely be big $ and I would be better off just replacing hard drives when/if they go bad. Quote Link to comment Share on other sites More sharing options...
Dingo Posted December 4, 2011 Report Share Posted December 4, 2011 OH HELL YES! Quote Link to comment Share on other sites More sharing options...
wilsons66604 Posted December 4, 2011 Report Share Posted December 4, 2011 This is cool! I would venture to guess that MyFordTouch will eventually explode while trying to index and "building commands" Is it working OK for you? Quote Link to comment Share on other sites More sharing options...
wlepse Posted December 4, 2011 Author Report Share Posted December 4, 2011 OH HELL YES! Is the 6864 the total count on songs between the two USB drives? And just to clariy you have both USB drives connected in the console? If you go to browse does it only show you artists and albums for the current USB? What about voice commands; if you ask for an artist that is on another USB can it find it? If the indexing does span the multiple devices to essentially make them one that would be awesome. Then the only issue I would have is to figure out how to do file maintenance on them. I was going to mess with this today so thanks for saving me the trouble of sitting out in the cold. Quote Link to comment Share on other sites More sharing options...
wilsons66604 Posted December 4, 2011 Report Share Posted December 4, 2011 Is the 6864 the total count on songs between the two USB drives? And just to clariy you have both USB drives connected in the console? If you go to browse does it only show you artists and albums for the current USB? What about voice commands; if you ask for an artist that is on another USB can it find it? If the indexing does span the multiple devices to essentially make them one that would be awesome. Then the only issue I would have is to figure out how to do file maintenance on them. I was going to mess with this today so thanks for saving me the trouble of sitting out in the cold. He's got 4 drives connected! Not just 2 Quote Link to comment Share on other sites More sharing options...
Dingo Posted December 4, 2011 Report Share Posted December 4, 2011 wlepse, they're all separate. It treats each as a different source. wilsons, good catch. Quote Link to comment Share on other sites More sharing options...
