wilsons66604 Posted November 22, 2011 Report Share Posted November 22, 2011 I like my touch to open feature on my tailgate. I wonder if there is any way to retro fit the new kick to open feature. Any ideas? Quote Link to comment Share on other sites More sharing options...
akirby Posted November 22, 2011 Report Share Posted November 22, 2011 Any ideas? Buy an Escape? Quote Link to comment Share on other sites More sharing options...
wilsons66604 Posted November 22, 2011 Author Report Share Posted November 22, 2011 Buy an Escape? That's an idea! Not a very good one though Quote Link to comment Share on other sites More sharing options...
akirby Posted November 22, 2011 Report Share Posted November 22, 2011 That's an idea! Not a very good one though But probably the only way to get that feature. Quote Link to comment Share on other sites More sharing options...
wilsons66604 Posted November 22, 2011 Author Report Share Posted November 22, 2011 But probably the only way to get that feature. I would think that a person could get one of the sensors and tie it into the tailgate motor somehow. Quote Link to comment Share on other sites More sharing options...
akirby Posted November 22, 2011 Report Share Posted November 22, 2011 I would think that a person could get one of the sensors and tie it into the tailgate motor somehow. Somehow being the key word. Chances are the sensor is tied into the computer module that controls the liftgate and you won't have that software on the Edge. Not to mention it's also tied into the Intelligent Access. Highly doubtful this could be retrofitted. Quote Link to comment Share on other sites More sharing options...
cal3thousand Posted November 22, 2011 Report Share Posted November 22, 2011 (edited) I think it's absolutely possible. You would need a proximity sensor or motion sensor (could be retrofitted from a cheap motion detector light from DealExtreme). Then use the signal from that sensor to control a relay that would trip the same circuit as the liftgate's external handle. That way, you are just replicating the button push on the liftgate whenever anything moves in the sensor's range. Would need to determined if a ground signal or positive signal is used first and construct the relay accordingly. Edited November 22, 2011 by cal3thousand Quote Link to comment Share on other sites More sharing options...
akirby Posted November 23, 2011 Report Share Posted November 23, 2011 (edited) I think it's absolutely possible. You would need a proximity sensor or motion sensor (could be retrofitted from a cheap motion detector light from DealExtreme). Then use the signal from that sensor to control a relay that would trip the same circuit as the liftgate's external handle. That way, you are just replicating the button push on the liftgate whenever anything moves in the sensor's range. Would need to determined if a ground signal or positive signal is used first and construct the relay accordingly. But that only works if the vehicle is unlocked, and if you're pushing the button on the keyfob to unlock it then you can just as easily push the button to open the tailgate. This is only really useful with Intelligent Access. Besides - it's not for sure that the tailgate switch is simply completing a circuit or if it's actually sending a signal over the data bus which would be way harder to duplicate. Edit: you also have to make sure the proximity switch doesn't activate when you drive over something or an animal walks underneath the vehicle. Edited November 23, 2011 by akirby Quote Link to comment Share on other sites More sharing options...
cal3thousand Posted November 23, 2011 Report Share Posted November 23, 2011 (edited) But that only works if the vehicle is unlocked, and if you're pushing the button on the keyfob to unlock it then you can just as easily push the button to open the tailgate. This is only really useful with Intelligent Access. Besides - it's not for sure that the tailgate switch is simply completing a circuit or if it's actually sending a signal over the data bus which would be way harder to duplicate. Edit: you also have to make sure the proximity switch doesn't activate when you drive over something or an animal walks underneath the vehicle. Sorry... I was working on the assumption of already having Intelligent Access since this just seems like an evolution. Did not mean to indicate it was mod that every Edge could participate in. linking to the IA system in this way will limit the car from opening the hatch while in drive. (but there are other situations that should be considered) Edited November 23, 2011 by cal3thousand Quote Link to comment Share on other sites More sharing options...
akirby Posted November 23, 2011 Report Share Posted November 23, 2011 Sorry... I was working on the assumption of already having Intelligent Access since this just seems like an evolution. Did not mean to indicate it was mod that every Edge could participate in. linking to the IA system in this way will limit the car from opening the hatch while in drive. (but there are other situations that should be considered) But don't you have to touch the door handle to unlock it when you have IA? I wonder if a regular keyfob works on an IA equipped vehicle? If it does you could program it and then have the proximity sensor simulate a double button press to open the hatch. Or trade it for a 2013 Escape. Quote Link to comment Share on other sites More sharing options...
cal3thousand Posted November 23, 2011 Report Share Posted November 23, 2011 But don't you have to touch the door handle to unlock it when you have IA? I wonder if a regular keyfob works on an IA equipped vehicle? If it does you could program it and then have the proximity sensor simulate a double button press to open the hatch. Or trade it for a 2013 Escape. With IA, all you have to do is tap the button on the outside of the tailgate (and of course have the IA fob in proximity). So my theory would be an auxiliary switch tapped into the tailgate switch's circuit that would mimic a person touching the button. Quote Link to comment Share on other sites More sharing options...
wilsons66604 Posted November 23, 2011 Author Report Share Posted November 23, 2011 With IA, all you have to do is tap the button on the outside of the tailgate (and of course have the IA fob in proximity). So my theory would be an auxiliary switch tapped into the tailgate switch's circuit that would mimic a person touching the button. That's what I was thinking could be done in some way. I have the IA and figured it would just be an extension of that. Quote Link to comment Share on other sites More sharing options...
cal3thousand Posted November 23, 2011 Report Share Posted November 23, 2011 That's what I was thinking could be done in some way. I have the IA and figured it would just be an extension of that. Getting a hold of a parts list for the new Escapes backend would help. Anyone with access? Quote Link to comment Share on other sites More sharing options...
Waldo Posted November 23, 2011 Report Share Posted November 23, 2011 Getting a hold of a parts list for the new Escapes backend would help. Anyone with access? Why worry about the Escape, just get a motion sensor from radio shack. Quote Link to comment Share on other sites More sharing options...
cal3thousand Posted November 23, 2011 Report Share Posted November 23, 2011 Why worry about the Escape, just get a motion sensor from radio shack. Just to understand if that's indeed how it is wired and not some data bus setup as Akirby mentioned as a potential Quote Link to comment Share on other sites More sharing options...
Waldo Posted November 24, 2011 Report Share Posted November 24, 2011 Just to understand if that's indeed how it is wired and not some data bus setup as Akirby mentioned as a potential A parts list isn't going to tell you how it's wired. But you can be sure it is on the network in the Escape, there really isn't anything that's not on the network anymore. Which is my point, what you're talking about - wiring into the existing trunk release switch - can be done with any old motion sensor. Quote Link to comment Share on other sites More sharing options...
Edgieguy Posted November 24, 2011 Report Share Posted November 24, 2011 Cool. First new project for next summer. Quote Link to comment Share on other sites More sharing options...
akirby Posted November 25, 2011 Report Share Posted November 25, 2011 So you have to pull out your keyfob, unlock the doors, then kick to open? Without the automatic unlocking of the IA system this just doesn't seem useful to me. Quote Link to comment Share on other sites More sharing options...
cal3thousand Posted November 25, 2011 Report Share Posted November 25, 2011 I was at the LA Auto show last night and had the Ford Rep demo the feature on their new Escape. Apparently, it uses a proximity sensor that can detect motion. This solves the issue of something running under your car when you are in range with the fob. Waving your foot on the ground under the car does nothing, but lift your shin until it gets close to the bumper and move it across the area and it will open. I'm beginning to think that a simple motion detector might cause unknown issues. The car itself was very attractive with many features I would like to see in an Edge sized vehicle including a properly retracting cargo cover and fold down seats that lock into place. Should be available by May 2012. Quote Link to comment Share on other sites More sharing options...
