Bluetooth
tinryland
  1. 1. My bluetooth in my ford just stopped working when i press the button nothing happens is this a serious fault
    • Is it hard to fix bluetooth ,mine just stopped working
      0
I've been able to "fix" mine by resetting it (pulling / replacing fuse #29) and it will work for 2-3 weeks, before failing again. Hopefully an actual fix will come with the new upgrade next year.
Cheers my fuse #29 is for dual climate control what does your handbook say your 29 is for ? thanks a lot
Fuse 29 does reset the MFT system...I have to pull it every once in a while...though with the 2.11 release I have had to do it less. Make sure the car is off, and you keep the fuse out for at least 30 seconds. When you put it back in you should here what sounds like the CD-Player ejecting.
Thanks a lot I will try it
