difference between
is there a difference between the nav system from say an 08 mkx and the 08 edge limited?
ive seen some things about thx or something on the lincoln one, and other then its silver....
is there any differences i should know about? and will they work in one another? ie i swap out my 08 limted's nav for the mkx nav etc
Thanks in advance all
I think the THX version is different but the non-THX version should be the same.
Any difference? The Lincoln may be setup for THX as stated before. Which is really no biggie. It will still work. The buttons and frame will probably be silver. Once again no biggie. Will it work in your Edge? Yes, it will. You can install it in less than half an hour. I put mine in yesterday at work. Took 20 mins to pull the old radio out and put the nav in.
Do you have the gps antenna too? If not you can find one on ebay for about $20. The connector may not fit right. But with a little tweaking from a dremel. You can make it fit. That's what I had to do.
The nav unit itself will be the same except for the color of the buttons. All the differences are in the configurations (software). But the THX components are not part of the Nav unit, so it's not like you're going to get the THX sound quality in an Edge just by changing the head unit. There would be zero point in doing the swap, unless something was broken with the unit in the Edge or you just like the silver buttons.
