miamil85 Posted November 14, 2011 Report Share Posted November 14, 2011 Hi guys, my back up system stopped working, it displays "PA ---" and does not sound. I don't have the owner's manual to see if there is a fuse for the back up system or not. I've disconnected the battery and re-connect and still get no sound. If not a fuse, could a bad sensor cause the system to shut down? Any input will help. Thanks Quote Link to comment Share on other sites More sharing options...
bbf2530 Posted November 14, 2011 Report Share Posted November 14, 2011 (edited) Hi guys, my back up system stopped working, it displays "PA ---" and does not sound. I don't have the owner's manual to see if there is a fuse for the back up system or not. I've disconnected the battery and re-connect and still get no sound. If not a fuse, could a bad sensor cause the system to shut down? Any input will help. Thanks Hi miamil85. :D You can download a PDF version of your Owners Manual here - LINK - Ford Owner Guides Best course of action would be to bring the car in for service, letting the Service Department properly diagnose and repair the issue (are you still under Warranty?). And for various reasons, disconnecting the battery for most problems like this is not a wise move, since it can wipe out trouble codes and create other problems. Let us know how you make out and good luck. :beerchug: Edited November 14, 2011 by bbf2530 Quote Link to comment Share on other sites More sharing options...
Mazz Posted November 14, 2011 Report Share Posted November 14, 2011 Are you sure it's not turned off in the MFT screen to the left of the steering wheel? Quote Link to comment Share on other sites More sharing options...
miamil85 Posted November 18, 2011 Author Report Share Posted November 18, 2011 Are you sure it's not turned off in the MFT screen to the left of the steering wheel? You mean the stick in the display that you press to switch from trip A - trip B - actual miles? bbf2530: thanks for the link, tomorrow i'm going to go over it. My edge is already out of warranty so i'm giving this a shot on my own before i take it in to the dealer. Quote Link to comment Share on other sites More sharing options...
miamil85 Posted November 18, 2011 Author Report Share Posted November 18, 2011 Would anyone know if there is a fuse for the reverse back up system? Quote Link to comment Share on other sites More sharing options...
