2007-Steven Posted November 4, 2011 Report Share Posted November 4, 2011 I put 20” wheels from a 2011 on my 2007. I had new bands and the TPMS installed and now I have a vibration issue. Drove for several months without the TPMS and was a very smooth ride. I’ve had the wheels re-balanced three times now and still have the issue. Anyone else have this problem? Suggestions? Quote Link to comment Share on other sites More sharing options...
wlepse Posted November 4, 2011 Report Share Posted November 4, 2011 Just to clarify....you took wheel from a 2011 and put them on a 2007? If so did you have the wheels machined? I thought the 2010 and earlier Edge's had a larger hub than the 11's and 12's, so if you didn't get this machined...could it be that one or more of the wheels are not on centered? If the wheel doesn't fit over the hub you would be relying on the lugs to center the wheel and if someone doesn't tighten them correctly it could become cocked. Quote Link to comment Share on other sites More sharing options...
Dingo Posted November 4, 2011 Report Share Posted November 4, 2011 Just to clarify....you took wheel from a 2011 and put them on a 2007? If so did you have the wheels machined? I thought the 2010 and earlier Edge's had a larger hub than the 11's and 12's, so if you didn't get this machined...could it be that one or more of the wheels are not on centered? If the wheel doesn't fit over the hub you would be relying on the lugs to center the wheel and if someone doesn't tighten them correctly it could become cocked. Yeah, that. Quote Link to comment Share on other sites More sharing options...
ablb Posted November 5, 2011 Report Share Posted November 5, 2011 We sold the hub caps off our 08 on craigslist and put after market wheels on. Drove it for a couple thousand miles, one trip across Utah at a legal 80 mph. Then one of the tpms came loose. Noticeable vibration. We took it back to Discount Tire and they fixed it. The tpms was not damaged. ab Quote Link to comment Share on other sites More sharing options...
2007-Steven Posted November 7, 2011 Author Report Share Posted November 7, 2011 To clarify, yes I did have the hubs machined. I work for a machine shop and there is absolutely no issue with off center machining. Had the wheels on the vehicle for three or four months before and put on 5000km (3000mi) before having the sensors installed. I was thinking along the lines of the band for the sensor not being tight or coming loose. Thanks for your posts. Quote Link to comment Share on other sites More sharing options...
flyerjmr33 Posted November 7, 2011 Report Share Posted November 7, 2011 To clarify, yes I did have the hubs machined. I work for a machine shop and there is absolutely no issue with off center machining. Had the wheels on the vehicle for three or four months before and put on 5000km (3000mi) before having the sensors installed. I was thinking along the lines of the band for the sensor not being tight or coming loose. Thanks for your posts. You can balance a hat box, but you can't make it roll unless it's perfectly round---- you possibly have a tire that is out of round. 4/64ths used to be the limit--- Quote Link to comment Share on other sites More sharing options...
Waldo Posted November 8, 2011 Report Share Posted November 8, 2011 I think the old band-style wheels actually had a counterweight cast into them to offset the weight of the TPMS sensors. Theoretically that could be overcome with enough wheel weights, but it makes the balancing job much more difficult. Quote Link to comment Share on other sites More sharing options...
