Hello....Need Help before going to Dealer....
RDWhite
Not sure where to post this, so hope here is OK. I have a problem, my first. I am a new member!
I have a lightly driven 2011 Edge Limited. A nice car until now. I have driven the car about 3600 miles in 13 months. I am retired and have another car, the reason for the low miles.
I drove the Edge once today and as always, a great drive, etc. Tonight, I started it up, backed out and put it into Drive and absolutely no power as if the accelerator is stuck on “1 mph”! I noticed an error code, a Yellow Wrench on the left display. I can’t clear it. I disconnected the battery for 30 minutes, but to no avail.
Anyone seen this problem before? I will take it to the dealer tomorrow. It will have to be towed as it goes about 2 mph max!
Please help!
Roger
Murphy, Texas
Please help!
Roger
Murphy, Texas
My guess is an ETC problem (Electronic Throttle Control).
Had Ford flat bed trailer the car to the dealer this afternoon, The on-board diagnostic said the following:
1. Powertrain Malfunction /
Reduced Power
2. What Is Happening?
Indicates that a Powertrain or All Wheel Drive (AWD) / Four Wheel
Drive (4WD) fault has been detected.
3. What Does This Warning Mean?
Powertrain Malfunction Indicator: Illuminates when an Electric Throttle Control
(ETC), Transmission, AWD/4x4 or Fuel System fault has been detected.
Contact your authorized dealer as soon as possible.
So, the service advisor called me at 5:00 and said the car arrived. Hopefully, I will know the verdict tomorrow!
Roger
Reduced Power
Roger
I'm still betting ETC......
The verdict is................!
Got the call this afternoon saying the "accelerator assembly" is shorted. Replacement is coming from Detroit. I didn't get to talk to the service adviser directly, so I do not know if the APPS failed or some other part of the ETC system.
Hopefully, I will be back on the road sometime tomorrow or maybe Saturday. Thank goodness as a backup I have the reliable 2008 F-150. Had 4 F-150/250's over the years and none of them ever left me stranded..
Stay tuned!
Roger
Stay tuned!
Roger
The accelerator assembly is the actual gas pedal. It has a sensor that determines how far you've pressed it and transmits that to the computer who then sends the command to the engine to change throttle position. It's just like a video game controller.
In other words.........ETC. I win! When do I pick up my prize?
Akirby, your check is in the mail…………!
Got the car today and all is well for the most part. Thought the radio was bad as I could not get any audio from it as I drove out of the dealership, but I guess the tech was playing his smartphone or some device on the radio, as I had to peck around on the display to get it back to normal.
Anyway, I am happy!
The tech report said:
1. EEC System diagnosis (Quick Test)
2. EEC System Diagnosis Repeat
3. EEC System – Diagnostic Pin Point Test
4. Accelerator Pedal Replace
EEC Test, Retrieve DTCS P1575 (Pedal Position Out of Self-Test Range) and P2138 (Accelerator Pedal Position). Perform Pinpoint Test DK. Pinpoint APP Sensor 1 (Accelerator Pedal Assy). Replace accelerator pedal. Clear codes.
Roger
