TyhlerGomez Posted October 26, 2011 Report Share Posted October 26, 2011 With 2009 FORD EDGE with Navigation, Im looking to add sync to it. The nav unit is programmed to accept Sync. But I just need to know what the parts numbers to look are for the Sync accessories. is there a specific part number for Sync patch harness? Steering wheel control? Amp harness? Any other wiring I would need.... Quote Link to comment Share on other sites More sharing options...
baum Posted October 27, 2011 Report Share Posted October 27, 2011 Is it a factory nav?? if so was it not factory installed? IMO it sounds like you have a base model edge without sync and someone installed a factory nav unit from like ebay. if its a factory installed unit it should have sync. being that you dont have sync its telling me its not a factory installed and someone bought a nav unit and installed it. There is more to it than just a "module". you need the dash harness (main harness for the vehicle), the mirror with the mic in it, you need the switch panel for the wheel, you may need a new clock spring for the steeling wheel. If you are after bluetooth it would be much easier to get the ford accesories piece ot a parrot cit. Quote Link to comment Share on other sites More sharing options...
TyhlerGomez Posted October 31, 2011 Author Report Share Posted October 31, 2011 Is it a factory nav?? if so was it not factory installed? IMO it sounds like you have a base model edge without sync and someone installed a factory nav unit from like ebay. if its a factory installed unit it should have sync. being that you dont have sync its telling me its not a factory installed and someone bought a nav unit and installed it. There is more to it than just a "module". you need the dash harness (main harness for the vehicle), the mirror with the mic in it, you need the switch panel for the wheel, you may need a new clock spring for the steeling wheel. If you are after bluetooth it would be much easier to get the ford accesories piece ot a parrot cit. The nav is factory. I just need to know the part numbers for the sync harness. I have everything else. Do you know the part no.? Quote Link to comment Share on other sites More sharing options...
