Walk-n-Edge Posted October 26, 2011 Report Share Posted October 26, 2011 Does anyone know if they will fit a 2007 Edge SEL? Quote Link to comment Share on other sites More sharing options...
Walk-n-Edge Posted October 26, 2011 Author Report Share Posted October 26, 2011 Nvm, looks like I got my answer. Looks like the new SHO, Explorer, Edge and Flex all share the same bolt pattern and backspacing. Quote Link to comment Share on other sites More sharing options...
Waldo Posted October 27, 2011 Report Share Posted October 27, 2011 But I think the Edge has a different center-bore. Quote Link to comment Share on other sites More sharing options...
Walk-n-Edge Posted October 31, 2011 Author Report Share Posted October 31, 2011 Yes the SHO has a smaller center bore than the Edge. That sucks, SHO wheels are pretty cheap on ebay. Quote Link to comment Share on other sites More sharing options...
mrdave Posted November 3, 2011 Report Share Posted November 3, 2011 I'm actually sporting some 20in SHO wheels on my 2011 at the moment since the center bore on the 2011+ is the same size as the Taurus. The only problem was that they barely rubbed on the front brake caliper so I had to get some small spacers. I'll try to get some pics up at some point. Quote Link to comment Share on other sites More sharing options...
mrdave Posted November 3, 2011 Report Share Posted November 3, 2011 1 Quote Link to comment Share on other sites More sharing options...
CCL123 Posted November 4, 2011 Report Share Posted November 4, 2011 Ahhhh! That looks amazing!!! How much were the rims? I love how they look like the chrome limited ones, like you could use the chrome one as your summer rims for the extra bling :P, then use this for the winter Quote Link to comment Share on other sites More sharing options...
bobkat72 Posted November 7, 2011 Report Share Posted November 7, 2011 What size spacer did you need? Quote Link to comment Share on other sites More sharing options...
mrdave Posted November 7, 2011 Report Share Posted November 7, 2011 What size spacer did you need? I used a 5mm spacer but you could probably get away with a 3 or even possibly a 2mm. When I test fitted the wheels without a spacer, they just barely rubbed the calipers in the front. The rear was fine. Quote Link to comment Share on other sites More sharing options...
p2edge Posted December 29, 2011 Report Share Posted December 29, 2011 how much you paid for the rims??? Quote Link to comment Share on other sites More sharing options...
coolwhip Posted February 16, 2012 Report Share Posted February 16, 2012 I used a 5mm spacer but you could probably get away with a 3 or even possibly a 2mm. When I test fitted the wheels without a spacer, they just barely rubbed the calipers in the front. The rear was fine. Hi ! Your edge looks great with SHO wheels! I want to do the same thing on my 4 day old edge and have some question before i buy the SHO wheels, please help! 1) Your SHO wheels, are they 20X8" or 20X9"? 2) Whats is the offset on SHO rims? 3) what size of tire do you have on them? 4) did 5mm spacer make you loose much threading on Lug studs? in other words, was there enough threading to secure the nuts 100%? Quote Link to comment Share on other sites More sharing options...
mrdave Posted February 16, 2012 Report Share Posted February 16, 2012 They're 20x8 and I believe the offset was 39mm. Tires are the stock size for 20in wheels, 245/50/R20. In my non-expert opinion, yes there was plenty of stud left with the 5mm spacer. 1 Quote Link to comment Share on other sites More sharing options...
coolwhip Posted February 16, 2012 Report Share Posted February 16, 2012 They're 20x8 and I believe the offset was 39mm. Tires are the stock size for 20in wheels, 245/50/R20. In my non-expert opinion, yes there was plenty of stud left with the 5mm spacer. Thank you so much MrDave! Quote Link to comment Share on other sites More sharing options...
JOYRIDER Posted April 25, 2012 Report Share Posted April 25, 2012 +1 looks great! You wouldn't happen to know the weight difference between the OEM Limited 20's and the SHO 20's would ya? Quote Link to comment Share on other sites More sharing options...
JOYRIDER Posted May 16, 2012 Report Share Posted May 16, 2012 (edited) I'm diggin the 2013 SHO wheels now Edited May 16, 2012 by JOYRIDER Quote Link to comment Share on other sites More sharing options...
JamesbialeK Posted September 19, 2012 Report Share Posted September 19, 2012 Hi, I have a quick question - I own a 2013 Ford Edge Sport AWD (with 22s) and I need to get winter tires for this coming cold Winer season here in Canada. Buying 22 inch winter tires are super expensive, so I've got a lead on a new set of Blizzak tires (245/45 R20) on seperate rims. They reportedly came off a Taurus SHO. The wheels (rims) are 8.5" wide with a '114.3 x 5' bolt pattern. Will these fit my Edge? Are there any issues I should worry about with the different in rims/tires? Your help us appreciated! Quote Link to comment Share on other sites More sharing options...
Waldo Posted September 20, 2012 Report Share Posted September 20, 2012 Hi, I have a quick question - I own a 2013 Ford Edge Sport AWD (with 22s) and I need to get winter tires for this coming cold Winer season here in Canada. Buying 22 inch winter tires are super expensive, so I've got a lead on a new set of Blizzak tires (245/45 R20) on seperate rims. They reportedly came off a Taurus SHO. The wheels (rims) are 8.5" wide with a '114.3 x 5' bolt pattern. Will these fit my Edge? Are there any issues I should worry about with the different in rims/tires? Your help us appreciated! They're not OE SHO if they're 8.5, the SHO has only ever had 20x8 rims. Why hold yourself to 20in? A nice set of 18 would probably save you a lot of money and give you better performance in the snow. 1 Quote Link to comment Share on other sites More sharing options...
JamesbialeK Posted September 20, 2012 Report Share Posted September 20, 2012 Only because they are cheaper. Blizzaks on aluminum wheels vs hankooks on steel, which I've heard may change your ride feel... I thought it was smarter... But that's why I'm here looking for advice. They're not OE SHO if they're 8.5, the SHO has only ever had 20x8 rims. Why hold yourself to 20in? A nice set of 18 would probably save you a lot of money and give you better performance in the snow. Quote Link to comment Share on other sites More sharing options...
RustyEdge Posted August 12, 2013 Report Share Posted August 12, 2013 I used a 5mm spacer but you could probably get away with a 3 or even possibly a 2mm. When I test fitted the wheels without a spacer, they just barely rubbed the calipers in the front. The rear was fine. Hey Dave, I know it was a while ago but do you remember where you got the spacers? Thanks, -Russ Quote Link to comment Share on other sites More sharing options...
2014WhiteEdgeSport Posted January 15, 2015 Report Share Posted January 15, 2015 I know this is an old topic, but if they have an offset of 39mm; which is the same as the edge, why would they rub? The Explorer has a wheel that looks the same, and the offset is 44mm... thoughts? Quote Link to comment Share on other sites More sharing options...
RustyEdge Posted January 15, 2015 Report Share Posted January 15, 2015 I have the Explorer Sport wheels on my '11 Edge and the fronts rubbed against the calipers due to the concave design. I believe that the SHO wheels are slightly concave as well where the oem wheels on the Edge are more flush in design. Quote Link to comment Share on other sites More sharing options...
2014WhiteEdgeSport Posted January 15, 2015 Report Share Posted January 15, 2015 I have done some searching and have seen the Explorer wheels rub, but this is the first I see the Taurus wheel rubs. RustyEdge... what size spacers did you need to usefor the Explorer wheels? If spacers are needed for both, I would definitely prefer the Explorer wheels as they are 8.5" as opposed to the Taurus wheel only being 8". They look identical in pictures... Quote Link to comment Share on other sites More sharing options...
2014WhiteEdgeSport Posted January 15, 2015 Report Share Posted January 15, 2015 Is there a difference between the front brake calipers/brackets on the 2014 Edge Sport AWD and the Limited/SEL AWD models? I am looking at the bracket/carrier to see if I buy a spare, if I can file the bracket slightly to get the clearance needed. Everything I am finding shows it will work on all except with 22" wheel... so are the Sport brakes different? Quote Link to comment Share on other sites More sharing options...
RustyEdge Posted January 18, 2015 Report Share Posted January 18, 2015 2014WhiteEdgeSport - I use 3mm hub centric spacers. 5mm would work as well but you don't need the extra clearance. The spacers were hard to find but I got them from motorsport-tech.com . Their website listed the incorrect hub size so I called and they had the right size in their records. They will make them any size you need really. 1 Quote Link to comment Share on other sites More sharing options...
