Circle3 Posted October 16, 2011 Report Share Posted October 16, 2011 I own the Edge 2011 Limited with HID headlights. This car has no Daytime Running Lamps (DRL). Local dealer says the BCM can not be programed to have DRL with HID lights. I see posts that Canadian dealers have the software to turn on DRL with HID headlights. Is there a third party solution for this in the US? Thanks, S Quote Link to comment Share on other sites More sharing options...
Scorpio Posted October 16, 2011 Report Share Posted October 16, 2011 (edited) A friend recently did this with a Ford he'd imported from the U.S. - the dealer did indeed enable DRL's by reprogramming the vechicle's PCM. Not sure what they had to actually change in the programming, but he definitely has DRL's working now on a U.S. market car. Edited October 16, 2011 by Scorpio Quote Link to comment Share on other sites More sharing options...
akirby Posted October 16, 2011 Report Share Posted October 16, 2011 A friend recently did this with a Ford he'd imported from the U.S. - the dealer did indeed enable DRL's by reprogramming the vechicle's PCM. Not sure what they had to actually change in the programming, but he definitely has DRL's working now on a U.S. market car. That was easily done on other Ford vehicles but the 2011 Edge is different for some reason. Quote Link to comment Share on other sites More sharing options...
factor99 Posted October 17, 2011 Report Share Posted October 17, 2011 That was easily done on other Ford vehicles but the 2011 Edge is different for some reason. DRLs are required in Canada. Since all the Edges come down the same assembly line there must be a way for Ford to change it. Quote Link to comment Share on other sites More sharing options...
akirby Posted October 17, 2011 Report Share Posted October 17, 2011 DRLs are required in Canada. Since all the Edges come down the same assembly line there must be a way for Ford to change it. Ford - yes. Canadian Dealers - yes. U.S. Dealers - no. No idea why. Quote Link to comment Share on other sites More sharing options...
