High pitch noise when power is on wihout engine.
I was working in my garage and my father was in his 2012 MKX getting used to the features.
Then I noticed this high pitch noise around me and thought someone's fire alarm was going off.
So I walked to the street to see which house, but the noise went away.
Came back to the garage and I heard the noise again.
Moments later I realized it was coming from the car.
When accessory/power is on while engine is not running, the car was making this noise. :banghead:
Very annoying if you want to have a radio on and wax the car or something, or someone in the car while you are working in the garage.
Anyone know why this is happening?
I asked a friend with 2011 Edge and it does the same thing.
Is it by chance coming from the subwoofer in the rear? The reason I ask, is because I had a high pitch whine coming out of the rear factory subwoofer. I was able to verify this, because I dropped in an aftermarket sub and amp. I tapped the high level signals coming out of the factory sub amp and ran them to the new amp. At first i could still hear a high pitch whine, but then i switch the amp crossover to Low pass, Instantly the noise was gone. Switching the crossover back high pass and the whine came back. hope this helps.
This noise is audible from 20 feet away from the car in some cases. Definitely not audio system related.
  • 4 weeks later...
