tmbubell Posted October 7, 2011 Report Share Posted October 7, 2011 (edited) Has anyone else experienced the following weird glitch with the vista roof? I had the Vista roof popped up the other morning and went to close it and it wouldn't close. Tryed both buttons to close and nothing. I then tried the auto open button and it opened to the standard open position, I then tried to close and nothing pushed the open button again and it moved to the fully open position, tried to close and nothing. Turned the Edge off and tried to close on Aux power , nothing Open and closed the door to get out of aux power. Turned the Edge back on, tried the vista roof buttons again , still wouldn't closed Finally on the third try of restarting the Edge the Vista roof buttons came back to life and I was able to close the roof fully Edited October 7, 2011 by tmbubell Quote Link to comment Share on other sites More sharing options...
wlepse Posted October 7, 2011 Report Share Posted October 7, 2011 Haven't had that issue before. We just can't get ours to do the one touch open even after doing the intialization. Maybe you should try the initialization?? Maybe it thinks the resistance to close is too high and thinks it must already be closed? Quote Link to comment Share on other sites More sharing options...
ahammet Posted October 7, 2011 Report Share Posted October 7, 2011 Has anyone else experienced the following weird glitch with the vista roof? I had the Vista roof popped up the other morning and went to close it and it wouldn't close. Tryed both buttons to close and nothing. I then tried the auto open button and it opened to the standard open position, I then tried to close and nothing pushed the open button again and it moved to the fully open position, tried to close and nothing. Turned the Edge off and tried to close on Aux power , nothing Open and closed the door to get out of aux power. Turned the Edge back on, tried the vista roof buttons again , still wouldn't closed Finally on the third try of restarting the Edge the Vista roof buttons came back to life and I was able to close the roof fully I most certainly have had this issues. And it was especially embarrassing when this happens while people are watching and it is raining! I've had issues with the roof not closing all the way - Took it into ford and they re-initialized the closing setting - That problem was at least solved. The issue you have described has happened to me a couple of times??? Quote Link to comment Share on other sites More sharing options...
