Ford Edge conversion for Europe
I just returned to Finland after a 3 year working trip in Canada and have brought back my 2008 Ford Edge Limited, not sold here and some changes needed:
1) Front turn signal and park light needed separating and park light needs to be white - Completed with small 5W bulbs in headlights as new park lights and turn signal lamps only operate as turn signals.
2) Turn signals required on side of car (either front fender near door or door mirror) - I found some LED turn signals that stick to door mirrors, wired to front turn signals and current draw is very low.
3) Day time running lights required on back and front - Taped auto light sensor and run with switch in this mode always.
4) Rear red fog light - Completed
The final requirement is amber turn signals on rear which, I planned to do with LED turn signal kit as used on door mirrors but the problem is that the live wire for the brake light activation is the same wire for the turn signal function so its not possible to separate the function to allow the brake to remain red and the turn signal to be amber.
Any ideas??????
