Floor jack point locations on a 2012 Edge
The Outrage
What are the recommended (safe) jacking points on 2012 Edge AWD when using a floor jack? Any assistance would be appreciated.
The recommended points are in your manual.
As normal FWD unibody vehicles, the pinch welds before the rear and after the front wheels are recommended. Get an adapter for your jack to accept that point if you don't already have one.
If you can't get your hands on one, I would use the floor jack on the reinforced subframe points by the control arm to lift, then put a jack stand on the pinch weld.
