FS: 18in new factory Ford Edge wheels
KonaBlueSport
Got a set of four(4) 18 in factory wheels for the Edge. Was thinking to use them as winters on my Sport but inherited a winter beater instead. The wheels are new and perfect. No tpms/ center caps. Looking to sell locally as shipping is going to be a bit expensive. asking $500 for them.... Pricw drop $400
Wheels are just like these
18_oem_ford_edge_wheels-aluminum_perfect_condition_2009_model_375_littleton_11467735.jpg
Edited by KonaBlueSport
  • 3 months later...
  • 6 months later...
  • 4 weeks later...
  • 7 months later...
  • 4 weeks later...
  On 6/3/2013 at 2:48 PM, biggrich2000 said:
will these fit on a 2008 ford edge?
The 2007-2010 Edge used a larger wheel hub opening of about 2.77 inches or 70.5 mm. The 2011-2013 use a smaller wheel hub opening of about 2.5 inches or 63.4 mm. You can have the centers machined out but you would be better off finding the correct wheel opening size.
It is a bit easier to put the older larger wheels onto a newer Edge with the smaller openings. You would need hub centric rings of the proper size.
He Is correct, the edge went to a smaller hub bore on the newer edges. Believe me, I learned the hard way. if you want to use them, itll cost about $200 to machine them.
