gonzmexican Posted September 20, 2011 Report Share Posted September 20, 2011 Hey Guys So as I have said, we have a 2010 Edge SE. My uncle has a 2011 5.0 and he just recently bought some new wheels and is getting rid of his stock 19 inch mustang wheels (the GT 5 spoke). Would these wheels fit on to the edge? I know they share the same bolt pattern. Has anyone done this yet? Thanks Quote Link to comment Share on other sites More sharing options...
hunter306 Posted September 20, 2011 Report Share Posted September 20, 2011 Probably want to check the backspacing and offset on the Mustang wheels vs. the Edge. I know my 2005 mustang had a unique offset that made them incompatible with some other vehicles with the same bolt pattern. Quote Link to comment Share on other sites More sharing options...
gonzmexican Posted September 20, 2011 Author Report Share Posted September 20, 2011 ^ thanks for the response..ill check that for sure, and since my uncle lives right around the corner i'll probably grab one of the wheels and bolt it up.. has anyone actually done this? I had a buddy who is on here (he has a 2011 white sport), who put the same wheels on his mercury mariner a while back..I am hoping it will work because my uncle is basically giving me the wheels Quote Link to comment Share on other sites More sharing options...
cal3thousand Posted September 20, 2011 Report Share Posted September 20, 2011 (edited) You're gonna have a tough time with offsets due to the FWD vs. RWD. Seems like the track would end up being wider. I'm interested to know what you find out though Edited September 20, 2011 by cal3thousand Quote Link to comment Share on other sites More sharing options...
gonzmexican Posted September 20, 2011 Author Report Share Posted September 20, 2011 ^ yea ill test fit um soon and let you guys know what they look like and if they will work Quote Link to comment Share on other sites More sharing options...
hunter306 Posted September 21, 2011 Report Share Posted September 21, 2011 FYI Did a bit more digging on this. The Edge has a +44mm offset. Looks like the 05' Mustang had a 42mm offset. 2mm is probably going to be close enough that you could pass on the edge, but I'd still check the backspacking and make sure you're not rubbing when you're at full lock. If anything, the wheels may just look a hair off sitting in the wells, depending on the design and the tire choice. I'm no pro at this stuff though, so be sure to get them checked out by someone who can verify the mustang wheels are ok for a CUV. One thing I'd watch for is the Tire Load (assuming the tires are still on there) Rating. Quote Link to comment Share on other sites More sharing options...
mrdave Posted September 22, 2011 Report Share Posted September 22, 2011 (edited) If the offsets are similar (2mm is nothing), then the only thing I'd be concerned about is the center bore. IIRC, the 2007-2010 Edges have a rather large hub diameter, meaning that most likely the center bore on OEM Mustang wheels is smaller and might not fit.... but check it out to make sure. Found the thread: http://www.fordedgeforum.com/index.php?/topic/5999-2011-edgemkx-hub-size/ Edited September 22, 2011 by mrdave Quote Link to comment Share on other sites More sharing options...
cal3thousand Posted September 22, 2011 Report Share Posted September 22, 2011 If the offsets are similar (2mm is nothing), then the only thing I'd be concerned about is the center bore. IIRC, the 2007-2010 Edges have a rather large hub diameter, meaning that most likely the center bore on OEM Mustang wheels is smaller and might not fit.... but check it out to make sure. Found the thread: http://www.fordedgef...gemkx-hub-size/ If this is the case, (that the Edge centerbore is larger) you can just have a machine shop bore out the rims to match the hub. At least the Edge hub isn't smaller. In that case, you'd need some custom spacers/hub adapters Quote Link to comment Share on other sites More sharing options...
mjd1001 Posted November 4, 2011 Report Share Posted November 4, 2011 Any update as to how this turned out? I have been looking/thinking of doing the same. I have access to a set of 2010 Mustang GT 19" 5 spoke wheels, and would like to know if they would go on a 2011 Edge. This is what I have found out: Both have the 5x114.3 bolt pattern Both have a 70.5 center bore (so i'm assuming the hub size isn't an issue) The only thing is I have found that most factory and aftermarkt wheels on the Edge are from a 38-45mm offset, while the mustang wheels in question are a 50mm I think. Normally, if there is no rubbing, I'd assume 5mm isn't an issue..but either way, i'm interested in how this worked for you. Quote Link to comment Share on other sites More sharing options...
bbf2530 Posted November 4, 2011 Report Share Posted November 4, 2011 Hi all. :D In addition to diameter, lug spacing, centerbore and offset, you need to know the width of the old wheels and new wheels. Unless both old and new wheels are the same width, the offset spec alone is essentially worthless. You must have both specs for valid fit comparisons. Once you know both specs, this Wheel Offset Calculator can be used to compare old wheel to new wheel fit - LINK - Wheel Offset Calculator Good luck. :beerchug: Quote Link to comment Share on other sites More sharing options...
dtw7227 Posted November 13, 2011 Report Share Posted November 13, 2011 (edited) I have the 19" premium wheels off an 2010 GT on my 08. I have had no issues with them at all. My Edge has the Eibach Pro-Kit springs to lower the stance a little and improve the ride. I decided to leave the sticky Pierellis on so now this thing really handles. Still rides very reasonable. I just got around to posting a picture of it today in the gallery. Edited November 13, 2011 by dtw7227 1 Quote Link to comment Share on other sites More sharing options...
Dingo Posted November 13, 2011 Report Share Posted November 13, 2011 Hmmmmmmmm. I suddenly want to move somewhere cold so that I have to buy winter wheels. Quote Link to comment Share on other sites More sharing options...
cal3thousand Posted November 14, 2011 Report Share Posted November 14, 2011 Hmmmmmmmm. I suddenly want to move somewhere cold so that I have to buy winter wheels. Those are nice looking wheels Quote Link to comment Share on other sites More sharing options...
Dingo Posted November 14, 2011 Report Share Posted November 14, 2011 Yeah, I never understood why people think winter wheels need to be ugly... Quote Link to comment Share on other sites More sharing options...
Eugenie39 Posted December 7, 2011 Report Share Posted December 7, 2011 I believe 19s are the perfect dimension on both the S-197 as well as SN-95. I don't mind Twenties around the S-197s, however the 19s allow for a bit more sidewall whilst not looking not big enough for the wheelwell. Even though it is just 1", it's a noteworthy distinction on possibly bodystyle. A 19" FR500 DD could be fairly sweet, however i additionally recall a person publishing a poll a few years back in regards to a potential brand new wheel for the newest Mustangs, that we believed looked fantastic. It had been the 5-spoke design as well as was not a duplicate wheel through what I remember. Does this ring a bell whatsoever? I think said design would be a good 19" contender. Not that a person asked, but the only difficulty I can see in gaining customers may be the pricing with regard to 19" wheels. I've not looked them upward recently, however i determine they still maintain a premium to more popular sizes such as Twenties and 18s. Quote Link to comment Share on other sites More sharing options...
