sjordan14 Posted September 18, 2011 Report Share Posted September 18, 2011 Hi I'm about to buy a 2011 Edge and am trying to decide if I should go for the Nav option. I have a Sprint Evo 4G phone (android 2.3). Do I need the nav or can I get what I need thru the Sync with my phone? Thanks Stuart Quote Link to comment Share on other sites More sharing options...
Edgieguy Posted September 18, 2011 Report Share Posted September 18, 2011 For the $795 by it at a minimum for the resale. It's def worth it. If it were $2795 or even $1795 I'd say pass. Quote Link to comment Share on other sites More sharing options...
sjordan14 Posted September 18, 2011 Author Report Share Posted September 18, 2011 For the $795 by it at a minimum for the resale. It's def worth it. If it were $2795 or even $1795 I'd say pass. That's a good point, thanks. But has anyone actually tried using the GPS on a Smartphone as opposed to the factory option? Does it work? Is it an ok alternative? Stuart Quote Link to comment Share on other sites More sharing options...
akirby Posted September 18, 2011 Report Share Posted September 18, 2011 That's a good point, thanks. But has anyone actually tried using the GPS on a Smartphone as opposed to the factory option? Does it work? Is it an ok alternative? Stuart Sure - they work fine. Most aren't quite as accurate - may be off a few hundred feet but they do work. The difference is the size of the screen and audio through the car speakers, plus a few other sync/Nav only features. Quote Link to comment Share on other sites More sharing options...
sjordan14 Posted September 18, 2011 Author Report Share Posted September 18, 2011 Sure - they work fine. Most aren't quite as accurate - may be off a few hundred feet but they do work. The difference is the size of the screen and audio through the car speakers, plus a few other sync/Nav only features. thanks Quote Link to comment Share on other sites More sharing options...
JOEHIO Posted September 19, 2011 Report Share Posted September 19, 2011 Definately go for the factory nav, well worth it. At the cost from factory,not a bad deal. Quote Link to comment Share on other sites More sharing options...
