07 Catalytic replacement
breen24
hello- my first post. I have a 2007 SEL and the check engine light code is showing a bad catalytic converter. The local dealer wants $1800 so I thought I would do it myself. I didnt realize the front cat is jammed in there fairly tight. It still looks doable but wanted to ask if anyone has replaced theirs and if they had some feedback about the r/r.
I'd try a local muffler shop versus a dealer. It can't be that much!
Funny story: reminds me of an '86 Bronco II I had. Emissions weren't such hot topics then and we lived outside the MSA that required them. Catalytic converter went bad; mechanic friend cut it open and gutted it, and welded it back shut. It had the 3.6 or 3.8 V6 with 5 speed manual. After the gutting you could run it up the gears high revving 1st and 2nd, then throw it in 3rd and let off the gas; about 3 seconds later as it revved down it would backfire and throw about an 18" flame out the tailpipe
