Masterface7 Posted August 20, 2011 Report Share Posted August 20, 2011 Hi, I was trying to have a stealthbox installed in my edge (2011 limited) and when the factory sub is removed right where the stealthbox would go the factory amp for the speakers is mounted. Has anybody had any luck moving this amp or more so has anybody installed a JL stealthbox into a 2011 edge limited? Quote Link to comment Share on other sites More sharing options...
ferneyhough Posted August 26, 2011 Report Share Posted August 26, 2011 Yes I had it done a few weeks ago & it sounds amazing, although it would be nice if I had 1 for the driver side also I also had a cache ceo6 installed so I could run the three amps I had installed. Quote Link to comment Share on other sites More sharing options...
Dingo Posted August 26, 2011 Report Share Posted August 26, 2011 An Audiocontrol Lc2i, a small amp, and a good 8 in the stock box works pretty well, also. Quote Link to comment Share on other sites More sharing options...
frybel Posted January 12, 2012 Report Share Posted January 12, 2012 An Audiocontrol Lc2i, a small amp, and a good 8 in the stock box works pretty well, also. Dingo, you have any pics of your setup? I've finally had enough of the Sony "premium" system and I'm ready for an overhaul. I'm looking at running exactly what you described and just wanted some advice on where you tapped the factory line out and what you replaced the sub with. Thanks. Quote Link to comment Share on other sites More sharing options...
PhantomX Posted January 17, 2012 Report Share Posted January 17, 2012 An Audiocontrol Lc2i, a small amp, and a good 8 in the stock box works pretty well, also. Which subs work well with that limited airspace in that box? I would love to do this but I'm not sure what subs will work well in that box. i also want to upgrade the door speakers to something a little cleaner... Quote Link to comment Share on other sites More sharing options...
Dingo Posted January 17, 2012 Report Share Posted January 17, 2012 frybel, off of the factory amp. PhantomX, I've got this one. Quote Link to comment Share on other sites More sharing options...
PhantomX Posted January 18, 2012 Report Share Posted January 18, 2012 frybel, off of the factory amp. PhantomX, I've got this one. Thanks Dingo, and that fit right into the factory box? That's an easy fix, a small amp, line out converter and sub. Sweet! Quote Link to comment Share on other sites More sharing options...
Dingo Posted January 18, 2012 Report Share Posted January 18, 2012 It was tight and required some heat. Quote Link to comment Share on other sites More sharing options...
