mnunes77 Posted August 20, 2011 Report Share Posted August 20, 2011 Trying to decide if I want to get HID's, but I worried they are going to be a pain install... Any thoughts? Thanks Quote Link to comment Share on other sites More sharing options...
dr.edge Posted August 20, 2011 Report Share Posted August 20, 2011 On 8/20/2011 at 1:49 AM, mnunes77 said: Trying to decide if I want to get HID's, but I worried they are going to be a pain install... Any thoughts? Thanks Actually pretty easy once you take the plunge. The biggest issue is where to mount the ballasts but there are lots of good options. The other issue is that they look great with any of the newer projector housings but you may not get the results you want if it's a regular reflector housing without some additional re-aiming of the headlights, etc. Quote Link to comment Share on other sites More sharing options...
ablb Posted August 20, 2011 Report Share Posted August 20, 2011 Easy if you have a 25 yr neighbor with 8” long fingers with an extra knuckle in each one. Seriously getting the bulbs in the housing was harder than mounting the ballast. You will find several good places to mount the ballast then realize the wiring harness is too short. These are in an 08 MKX with projectors. ab Quote Link to comment Share on other sites More sharing options...
RaulB Posted August 20, 2011 Report Share Posted August 20, 2011 super easy.. took me a whole 20 min to install them and mount the ballast... the kits should just be plug and play depending on where you buy them -Raul Quote Link to comment Share on other sites More sharing options...
cashmoney0596 Posted September 23, 2011 Report Share Posted September 23, 2011 is the factory bulb a combo hi/low. i thought i saw somewhere that there is a flapper that switches between the 2. basically do i need hi/low hids or is there another bulb in there for the highbeam Quote Link to comment Share on other sites More sharing options...
DunePearlEdge Posted September 23, 2011 Report Share Posted September 23, 2011 Do the HIDs form a solid interface with the existing headlamp on the 2007-2010 edges? I have seen installs on vehicles other than edges which required crudly trimming the stock rubber grommit and the space between the HID bulb and the rubber allowed moisture to enter. Quote Link to comment Share on other sites More sharing options...
offthebnch Posted October 2, 2011 Report Share Posted October 2, 2011 On 9/23/2011 at 12:59 AM, DunePearlEdge said: Do the HIDs form a solid interface with the existing headlamp on the 2007-2010 edges? I have seen installs on vehicles other than edges which required crudly trimming the stock rubber grommit and the space between the HID bulb and the rubber allowed moisture to enter. It's pretty easy. You're correct. I had to trim the HID's a little to fit. You will need to drill holes into the covere of the light housing. The hid kit should come with agrommets that will still seal to prevent moisture. I used body molding double stick tape to mount my ballasts. They seem to be holding them pretty solid. But I'm eventually going to mount them properly with screws. Just didn't want to drill any new holes at the time. But definitely worth the mod. Quote Link to comment Share on other sites More sharing options...
tommy salcedo Posted October 10, 2011 Report Share Posted October 10, 2011 Yes please make sure you get a proper projectors and re-aim your headlights with the proper dip profile so that you do not have worse performance than originally or, worse, blind all incoming traffic. Thanks. Quote Link to comment Share on other sites More sharing options...
cocolin3 Posted April 10, 2012 Report Share Posted April 10, 2012 The hard part was taking the bumper off. I took out the light housing and mounted the ballast on the side, and I used the mounting bracket to hold it in place. Of course I had halogens and hated the yellow light, but i like it 10X better now that my whole care looks like a moving LED bulb. Quote Link to comment Share on other sites More sharing options...
c_bova Posted April 11, 2012 Report Share Posted April 11, 2012 i followed kc300c install and it was a piece of cake, I didn't even take the stock intake out. Had it installed in 15-20min, and I mounted mine on the side of the headlight where the stock ones would go. Quote Link to comment Share on other sites More sharing options...
mmcclure Posted April 11, 2012 Report Share Posted April 11, 2012 (edited) I also followed kc300c's advice and video. Go with the DDM tuning 55W 5000K and you will not have any problems Edited April 11, 2012 by mmcclure Quote Link to comment Share on other sites More sharing options...
PrinzII Posted June 10, 2012 Report Share Posted June 10, 2012 I had an easy time after getting the DRL module and warning canceller. Quote Link to comment Share on other sites More sharing options...
