bigk40plus Posted August 15, 2011 Report Share Posted August 15, 2011 I service my own cars. I did my first oil change. I have a floor jack and when I was going to lift the edge from the front I notice that I was not able to lift the front from the center of the car also when I lifted it from one side it wanted to bring up the rear wheel. Looking for digestions on a better way to lift the edge....pic are welcome Quote Link to comment Share on other sites More sharing options...
akirby Posted August 16, 2011 Report Share Posted August 16, 2011 I service my own cars. I did my first oil change. I have a floor jack and when I was going to lift the edge from the front I notice that I was not able to lift the front from the center of the car also when I lifted it from one side it wanted to bring up the rear wheel. Looking for digestions on a better way to lift the edge....pic are welcome Get some rhino floor ramps - they work great and are much easier and safer than the floor jack. The floor jack is meant to be used in the normal location - just behind the front wheel and just in front of the rear wheel. It's not designed to be jacked anywhere else. It will lift up the rear wheel because it's a unibody design and relatively stiff - that's normal. Quote Link to comment Share on other sites More sharing options...
Fingernip Posted August 16, 2011 Report Share Posted August 16, 2011 +1 on the ramps. I never jack up my cars unless i need to take off a wheel or take weight off suspension. Quote Link to comment Share on other sites More sharing options...
cal3thousand Posted August 17, 2011 Report Share Posted August 17, 2011 For oil changes... get a creeper no need to lift the vehicle. For things REQUIRING lifting of vehicle, jack each side at a time and put a stand under each side. Quote Link to comment Share on other sites More sharing options...
