fishx65 Posted August 14, 2011 Report Share Posted August 14, 2011 Went to hardwire my radar detector into a new 2011 SEL today and ran into some trouble. What's up with the short posts on the mini fuses? Had a heck of a time getting the positive wire attached to these stuby little things. I've never seen this new fuse design until today. Didn't check but does a regular mini fuse slide into these outlets? Quote Link to comment Share on other sites More sharing options...
dr.edge Posted August 14, 2011 Report Share Posted August 14, 2011 Went to hardwire my radar detector into a new 2011 SEL today and ran into some trouble. What's up with the short posts on the mini fuses? Had a heck of a time getting the positive wire attached to these stuby little things. I've never seen this new fuse design until today. Didn't check but does a regular mini fuse slide into these outlets? They're called low profile ATM fuses and you can substitute a regular ATM style fuse in their place if you want to use a fuse tap to get power to an accessory. The only issue is whether or not the fuse cover will fit back into place (usually it does). I ran into the same issue when I was wiring my radar detector in and used a regular ATM fuse of the same capacity, didn't have any problems. It does make you wonder why they decided to change formats though. Quote Link to comment Share on other sites More sharing options...
