chiefc2 Posted August 7, 2011 Report Share Posted August 7, 2011 I have an 07 Edge AWL SEL that has an annoying ping in the motor. I've had it back to the Ford dealer several times bit they have been unable to correct the problem. I know the owners manual says the a slight pinging is normal but it has gotten louder as time goes on. It also has 39000 miles on it, so it is out of warantee. Has anyone else had this problem and if so what is the solution? I love this car except for that. Any help would be greatly appreciated. Quote Link to comment Share on other sites More sharing options...
akirby Posted August 7, 2011 Report Share Posted August 7, 2011 I have an 07 Edge AWL SEL that has an annoying ping in the motor. I've had it back to the Ford dealer several times bit they have been unable to correct the problem. I know the owners manual says the a slight pinging is normal but it has gotten louder as time goes on. It also has 39000 miles on it, so it is out of warantee. Has anyone else had this problem and if so what is the solution? I love this car except for that. Any help would be greatly appreciated. Does it go away when you use 89-93 octane? Quote Link to comment Share on other sites More sharing options...
chiefc2 Posted August 8, 2011 Author Report Share Posted August 8, 2011 Does it go away when you use 89-93 octane? I've tried higher grade gasolines and also octane booster from the auto parts store. Nothing seems to work. Quote Link to comment Share on other sites More sharing options...
akirby Posted August 8, 2011 Report Share Posted August 8, 2011 I've tried higher grade gasolines and also octane booster from the auto parts store. Nothing seems to work. Then it's not a typical ping or engine knock. Time to find a mechanic. Quote Link to comment Share on other sites More sharing options...
