edgemaster Posted August 4, 2011 Report Share Posted August 4, 2011 Guys, I need to replace the windshield washer nozzles. Do I need to use original Ford nozzles (probably cost a small fortune) or can I install aftermarket parts? Thanks, Ed Quote Link to comment Share on other sites More sharing options...
cal3thousand Posted August 4, 2011 Report Share Posted August 4, 2011 Guys, I need to replace the windshield washer nozzles. Do I need to use original Ford nozzles (probably cost a small fortune) or can I install aftermarket parts? Thanks, Ed Aftermarket will work. Beware though, the spray pattern on the stock ones is pretty good. If you get aftermarket, make sure the spray pattern is fan-like and will cover your glass properly. Nothing worse than not having enough fluid on parts while too much on others. My plan is to take mine off, and give them a coat or two of touch up paint to body match them. Quote Link to comment Share on other sites More sharing options...
edgemaster Posted August 4, 2011 Author Report Share Posted August 4, 2011 Well, thanks for the quick response. I don't think aftermarket parts would describe their particular spray pattern. Probably have to go with the originals. Quote Link to comment Share on other sites More sharing options...
kf4nnq Posted March 23, 2012 Report Share Posted March 23, 2012 Just had to replace both nozzles on my 07 Edge with 72k miles on it. They both stopped working and then broke apart when I tried to work with them. Looks like dry-rotted plastic. Ordered replacements from Jacky Jones Ford on line and they arrived in four days. Will install them tomorrow. Looks like this happens to a lot of Edge owners. Quote Link to comment Share on other sites More sharing options...
edgemaster Posted March 23, 2012 Author Report Share Posted March 23, 2012 How much did they charge? Quote Link to comment Share on other sites More sharing options...
rboe Posted July 5, 2012 Report Share Posted July 5, 2012 My drivers side nozzle broke where the hose goes into the nozzle. There is a sleeve still attached to the hose; is that glued on? I may have to replace the hose and both nozzles (which at this point it may not be a bad idea from what I just read here). Thanks! Quote Link to comment Share on other sites More sharing options...
Cards227 Posted August 7, 2012 Report Share Posted August 7, 2012 I had my whole system replaced earlier this spring by the dealer due to dry rot. 2 nozzles, the connectors, and hoses installed ran about $34. Quote Link to comment Share on other sites More sharing options...
Ironpeddler Posted March 10, 2014 Report Share Posted March 10, 2014 I had a feeling, before I decided to check here, that there was an issue with these. This seems to be an issue of crummy plastic parts. I can honestly say...in all the cars I've owned...that I ever had a windshield washer nozzle disintegrate in my hands like this. Bought a new set ...OEM Ford Part...for $16.88 delivered from a Ford dealership in Braintree, MA on eBay. The lines seemed to be OK, my dealer wanted over $100 to diagnose the problem.."Yeah, the pumps go on those cars all the time"...and it wasn't a pump, the connection broke at the nozzle. What thieves. Thanks for the confirmation guys! Quote Link to comment Share on other sites More sharing options...
