Edgar Edgeworthy Posted August 2, 2011 Report Share Posted August 2, 2011 Where can i find the recommended tire inflation for my 2011 Edge Ltd. with 20 inch wheels? Quote Link to comment Share on other sites More sharing options...
igcitng Posted August 2, 2011 Report Share Posted August 2, 2011 On 8/2/2011 at 4:35 PM, Edgar Edgeworthy said: Where can i find the recommended tire inflation for my 2011 Edge Ltd. with 20 inch wheels? Inside of the door. Quote Link to comment Share on other sites More sharing options...
bbf2530 Posted August 2, 2011 Report Share Posted August 2, 2011 On 8/2/2011 at 4:35 PM, Edgar Edgeworthy said: Where can i find the recommended tire inflation for my 2011 Edge Ltd. with 20 inch wheels? Hi Edgar. :D As igcitng alluded to, most Fords have a sticker with the tire and inflation specs located on the drivers side door jamb or door itself. Good luck. :beerchug: Quote Link to comment Share on other sites More sharing options...
Edgar Edgeworthy Posted August 2, 2011 Author Report Share Posted August 2, 2011 On 8/2/2011 at 5:06 PM, igcitng said: Inside of the door. Duh, thanks. Quote Link to comment Share on other sites More sharing options...
flyerjmr33 Posted August 2, 2011 Report Share Posted August 2, 2011 On 8/2/2011 at 8:07 PM, Edgar Edgeworthy said: Duh, thanks. The owner's manual is another good place for that information! Quote Link to comment Share on other sites More sharing options...
igcitng Posted August 2, 2011 Report Share Posted August 2, 2011 On 8/2/2011 at 8:49 PM, flyerjmr33 said: The owner's manual is another good place for that information! I don't think it lists specific pressures, Edge has many different tires. And sometimes you cannot go by what is on the tire if the same tire is used for different applications. Quote Link to comment Share on other sites More sharing options...
flyerjmr33 Posted August 2, 2011 Report Share Posted August 2, 2011 On 8/2/2011 at 9:24 PM, igcitng said: I don't think it lists specific pressures, Edge has many different tires. And sometimes you cannot go by what is on the tire if the same tire is used for different applications. But it does describe what the sticker looks like and where it is located----- Quote Link to comment Share on other sites More sharing options...
bbf2530 Posted August 2, 2011 Report Share Posted August 2, 2011 On 8/2/2011 at 9:24 PM, igcitng said: I don't think it lists specific pressures, Edge has many different tires. And sometimes you cannot go by what is on the tire if the same tire is used for different applications. Hi igcitng. :D You are partially correct. Ford Owners Manuals rarely include recommended tire pressures. The Owners Manual actually tells us to consult the sticker on the drivers side door sill/jamb. However, just to avoid confusion: You can never "...go by what is on the tire...". The pressure listed on the tire sidewall is the "maximum cold inflation pressure". And generally speaking. no auto manufacturer would ever recommend coming close to that "maximum cold inflation pressure" listed on the tire sidewall. You use the auto manufacturers recommend cold inflation pressure listed on the door sill/jamb sticker. Even a few psi higher (i.e. 2-5psi) can be beneficial for fuel mileage, handling, tire life, etc. with little effect on ride comfort. But for safety purposes, never inflate to the maximum pressure listed on the tire sidewall. Hope this information helps and avoids any confusion for others. Good luck. :beerchug: Quote Link to comment Share on other sites More sharing options...
