ltk20 Posted July 21, 2011 Report Share Posted July 21, 2011 Hi, I have a 2011Edge with the Touch Screen Sync system, No GPS, though. Since yesterday, my stereo is not even an option on the touch screen to turn on. If I hit the master power button on the rotating volume knob it makes the initial sound like it's about to come on, but nothing happens. I checked the fuses for both the stereo and the amps along with a few others but they all seemed fine. Any help would be highly appreciated. Quote Link to comment Share on other sites More sharing options...
Mazz Posted July 21, 2011 Report Share Posted July 21, 2011 You might try pulling fuse 35, wait a few minutes and then replace it, then start the vehicle. Or, disconnect the negative battery terminal, wait a few minutes and then reconnect it, then start the vehicle. That will force a cold boot of the system. Quote Link to comment Share on other sites More sharing options...
ltk20 Posted July 21, 2011 Author Report Share Posted July 21, 2011 I appreciate the quick reply... Before checking back for a reply I ended up syncing my iPhone to it via Bluetooth and then ran the vehicle diagnostic. I didn't have an account established so I wasn't able to get a system report back but the car still ran a bit test which seemed to fix the problem. What happened to the days of an on and off switch right? Ha Thanks for the help. Quote Link to comment Share on other sites More sharing options...
pjo85 Posted July 23, 2011 Report Share Posted July 23, 2011 I appreciate the quick reply... Before checking back for a reply I ended up syncing my iPhone to it via Bluetooth and then ran the vehicle diagnostic. I didn't have an account established so I wasn't able to get a system report back but the car still ran a bit test which seemed to fix the problem. What happened to the days of an on and off switch right? Ha Thanks for the help. I have had the 8" screen go blank, nav system failure and phone connectivity issues. Each one was resolved by resetting fuse 29. I leave the fuse covers off now. Quote Link to comment Share on other sites More sharing options...
