Ford EDGE 2008 protection of the accumulator against the full category?
EDST777
Hello. Friends protection of the accumulator against the full category is established on Ford EDGE 2008?
For example if not to switch off a passing light at the switched off engine that will be with the accumulator?
Sorry, we do not understand. Please try again.
I think you are asking if the 2008 Ford Edge uses a relay to turn off the lights to protect the battery (accumulator) in case the lights are left on accidentally? The answer is YES - it's called Battery Saver. If either the headlights or the interior lights are left on for 30 minutes they will be turned off automatically so the battery isn't drained.
Thanks you, you perfectly have understood me!)
