Modifs
SELAWD2011
  On 7/20/2011 at 2:03 PM, SELAWD2011 said:
Hi guys,
I just got an EDGE SEL AWD 2011 and was looking at adding some extra HP to it. I was wondering if any of you found a performance chip that could be added without voiding the waranty.
No chips on any new Fords but you can get a SCT tuner that will help a little. It won't void the warranty unless it causes a problem (e.g. they won't refuse to fix a bad wheel bearing because you have a tune installed. But if you have en engine problem that could be caused by a tune then they could deny that but they have to prove reasonable cause).
